Surfrodz definitely
How is the ground clearance on this enclosure?
It’s pretty good if you use risers, just select the desired riser thickness depending on the wanted clearance, board looks amazing on any rises setup
This is with riptide powercable riser And please note the enclosure isn’t screwed so a few more mm after
Wow nice man I like it. Although there is enough room in the current enclosire
So here is the final version of the Moonshine Sidekick enclosure with heatsink.
Yes I do. I make the cutout and install the heatsink if they are ordered
Here is the hs11/HolyPro 35 DS version:
Ohhhh boy… yeah im buying a sidekick. This is happening. That enclosure is sexy.
So is the heatsink somewhat universal or made for focboxes?
With the current heatsink, it looks like it’ll only fit focboxes.
Can’t wait to see your enclosure disign on the kuthaka
Damn i should almost have ordered a heatsink.
Wow nice job integrating the heatsink… Too bad I want to top mount my emtb I know I’ll never get something that slick with these two left hands
The heatsinks are only suitable for two single focboxes, it wouldn’t work on the Unity or any other ESC
How are they attached to the enclosure? Epoxy?
Yes. It’s epoxied to the enclosure
How is the KutThaka enclosure coming along?
It’s going to take some weeks to finish it
There’s actually plenty of space for a 12s3p in your single stacked enclosure for the Jet spud.
