Thanks freaking epic! isn’t the BMS there being squished too much?
You will love that deck, it’s all I ride these days!, us the most top baseplate holes and most bottom ones, the look of the board is perfect.
I’m down for one SS for a 10s3p and dual Focboxes
The bms is sitting on top, looks to be doing just fine. Board looks awesome, really love the enclosure, it’s a work of art. Can’t wait to finish the build and try it!
@Eboosted I saw you are making an enclosure for 12s4p 20700 on the Trampa HolyPro35 deck. Will it be the same as for the Trampa street carver? I’m building a 10s4p 20700 pack with a bms (same size as 8*20700 cells) and Focbox Unity. I have made a rough fiberglass enclosure for it with 16 cells in the 1st pod then 3 pods with 8 in each then the last pod is the same size as the 1st and has the electronics. When it breaks I’d like to get one of yours to really finish off my deck.
I wonder where are you guys getting the NCR20700A batteries these day, they are still pretty expensive and difficult to source. The NCR20700B have a pretty lame maximum discharge rate for a battery that big, good capacity though
This is where I got mine. The price per Wh is a bit higher but the package shape means I can get a 17Ah 10s 4p in 400mm of battery length instead of say a 30q pack with 15Ah 10s5p taking up 450mm of battery length. 2mm thicker and 10 mm wider to gain that much battery capacity in a shorter pack, that’s still got for around 80A, That’s worth the few extra dolarydos for me.
On the 20700B you can only get 15A on each cell for a total of 60A on a 12S4P form, discharge is too low for a Carver deck with pneumatics from my point of view. I rather use a 12s4p made of Samsung 30Q 18650 or even Sony VTC6 instead for 80A discharge.
If range is very important to you a better choice would be a NCR20700A, that on a 12S4P array will give you a craxy 120A of discharge, that’d be EPIC!
The Moonshine sidekick DS enclosure is ready
Can’t wait to try this beast on the board, it has a lot of room for a full size BMS and 2 VESCs 6.
As the Sidekick is a motorcycle inspired deck I came up with a a grip tank bike design for it:
The enclosue is able to hold more than 60 18650 cells, however a 12S6P would be perfect if want to run a full size BMS even the BIG ones plus two FocBoxes.
If you want to go crazy and need extremely long range you could fit a 10S8P, completely unnecesary for everyday use but there are a lot of insane guys around here so they might find this a pretty nice starting point.
At the bottom I left a flat surface in order to allow an ESC aluminum heatsink fitment.
Omg… its beautiful. Need to see it on the board.
Gorgeous!! Do we get to see it with the deck?
I’m disassembling the SS enclosure at the moment, hold on a sec
Here are some pictures on the board, sorry for the messy board, just came from a long ride.
Here is the 12S5P with 2 ESCapes and the Bestech HCX-D596 BMS
From your previous post, seems that you didn’t ride with the new enclosure yet. Would love to see if the motor mount and motor make contact with the enclosure while carving. Also how many 20700 cells would it be able to fit?
No. The enclosure has just been finished, I was just test fitting it to the deck.
I’m going to makea new 12s5p pack for it.
The mounts do not touch the e closure at all, they are pretty far away not even pushing one corner with both feet and jumping
Beautiful! Can’t wait to see it.
What a sweet deck, perfect for a light esk8 project! Enclosure design starting now
What board is that ?
Loaded Kuthaka!
Does It Flex?
Has almost no flex for me. It’s way too small to have much of any flex
