I have no experience with high C rated packs but I thought they should last longer beside the advantage of less voltage sag. They are too expensive for short usage IMO. Would be interesting to hear some more feedback from users from high C rated packs how long they last.
BTW I don’t have problems with too much sag with 15C 8Ah, usually it’s about 1V, on full throttle 3V. But I guess 15C is the reason why they puff and loose capacity that fast.
That is still double compared to the voltage sag I see at 60C/12Ah.
As long as the combined output rating is not surpassed and the packs stay cool, the higher C rating should not lead to a substantially higher lifetime. As soon as they start puffing or become hot, you have already surpassed the limit.
The Graphene packs do deal with depletion better (riding till 3.4V is possible, where 30C packs for example start cooking and should be limited to 3.7V minimum).
Had some fun in the narrow single trail at dirt park. It is very difficult to ride because it’s tiny and has tight curves, not mountainboard friendly. Slightly leaving the trail means 99% chance of falling which happens quite often
Haha true but it was a short session without testing the limits. The tricky parts are the curves/birms with stones and holes on the sides. Also in the grass are big stones, bricks and wood. But normally falling doesn’t hurt at that low speed.
Had a hardcore ride and destroyed 3 tires and bent the metal plate of the gear box .
But it was a lot of fun shredding stones and crazy inclines up to 40 degrees (83%). Fortunately I shot some video scenes there so I have evidence .
The wall of fear
Unfortunately I’ve chosen the wrong angles so in the video exactly the same 40° wall looks like kindergarden
It is so freaking steep and there are some more walls to climb
How to slice your tires…
I would love to shoot more with better angles but I think it’s enough damage for now.
Both rear tires have several slices like this
and the front tire/tube… well
Furthermore the motor shifted down, the backlash was gone and there was a noise. In the beginning I thought it’s the faulty motor but after a while it sounded like straight gears and I started to carry it home. I degreased the drive train and it seems like there is no damage at all
I was riding without backlash and sand in the gears, Jesus
Applied much more Loctite this time so it shouldn’t move again. It’s getting too late to make noise so I finish this tomorrow but it’s still 80% done.
I guess it’s time for the cheap aliexpress tires if I find enough tubes.
Lil bit help for flat tyres, Its ment for bikes, but who cares. When applying in 6,5-9" tyre. make a lot of cuts in tape along the sites to the center of tape, so you dont get curves, and then use some heavy duty tape to fix it with tyre so the tube wont get caught in between and get slice down. Then u can put on tyre with the tube on the rim and apply slime inside tube. Just remember to change tubes and apply new slime every year just in case.
I was doing lot of forest biking when I was younger, healthier and more handsom, so before I found out ‘anti-puncture tape’ what I did, was applying old tubes between tyre and new tube, but that stuff was meh. This shit is srsly doing its job. Just maka sure u fix it to tyre with tape. It can slice your tube. And slime helps with small cuts and holes. When u blow up tyre nothing can help(except lots of grass, gravel steel legs and concrete ass xD)
I break a lot of shit as well and sometimes it makes me kind of thinking it’s a sign that esk8ing is not for me…but than I read your stories and how much you destroy and understand i‘m kind a lucky how less broke on me
I’m not afraid because it’s DIY so a lot of things are fixable without high costs. Imagine we would ride commercial boards, that would suck and we could never ride because of external repairs
I hate it when I destroy things but love to ride that this can happen, that’s the best! It’s really funny when I remember watching videos of @Nowind and thought what the hell is he doing. Why he is treating his board like his enemy, why he grinds the truck on the rail again, whaaat burn outs and that sliding must be very bad for the tires and so on.
Now I understand why
For comparison of some costs, last winter I went snowboading. A day ticket costs 43.50€ plus 20€ food and travelling costs so 80-100€ for a single day. For the same amount of money I could kill at least 8 tires or 1 motor and personally I enjoy it more to pay for destroyed parts than paying for a stupid day ticket.
Is it that sharp? Or because of the cuts on the sides you did? I would be afraid what happens when the tape stops sticking after a while
Not sure if this is a serious question but same setup as before, just need new tires.
but to be fair, I hope to get way much more days on my esk8 than on the snowboard. Buying a “day ticket” for every weekend I´m out on my esk8 would be pretty exensive as well.
my thoughts as well when I just started with all that here.
I was crying to see the tires wearing down on the burn outs and asked myself, why…just why… isn´t that just expensive???
now I understand that way better… have a box of spare wheels at home and don´t mind to swap them all out during one season.
I made the cuts because its for bike applications and when I applied it in small tyres it was all curvy along sites. Than I applied heavy duty tape so it wont move inside and just in case for peace in mind. It will stick forever, because u will have inflated inner tube so it will be pushed to tyre even more.
