Do you mean the bluetooth bms or the evolve one? The two wires on the bluetooth bms is actually a temperature sensor.
On the bluetooth one i thought mabe there was a built in eswitch useing the 2 black wires comeing out
I know there are pads on the circuit board for a switch though if you wanted to use one.
Yes pls, How do We process This?
Sorry Im new in This forum and i did try to PM but it didnt worked
It’s ok. New members actually do not have access to private messaging until they reach a certain rank.
Did you have to lower the heatsink to fit the unity in your CGT? I’m finding it’s too tight a fit for the sensor cables and it’s stuffing up the board’s performance when rider weight is applied
No, you just have to strip it down
Dud’s those mods looks great.
I need to talk with you about some stuff…
This is what i did with mine, swapping out different wheels just to see which one i like better.
OMG those gears are as big as the tires WOW that’s a hell of a MOD
unity?
No dual Foc.
whats the battery size, some people have been looking for a mod like this
12s 4p Samsung 30Q
Strip it down? Do you mean remove the heatsink built in to the bottom of the unity?
no, just remove the silicone cover. and I used the OG evolve heatsink. And because space is so tight I used double sided heat transfer tape only. It should fit
Hmm that’s strange, in my enclosure it’s still too high doing that as the sensor cables are being compressed to the point of causing the motors not to run properly
