Well I have some area rf1 and some area k5 with extended axels that are about 45mm and I have the e caliber sitting around with a 47mm axel so I was verifying that any truck with 14+mm axel from the stock length at 35mm should work
Yeesss please. these are sooo nice okp
Sold sold sold …I’ll take a couple sets of mounts and a couple sets of magnum wheel pully when your complete this build 100% …thank you so much
Good news. I’m done with the 3D prototyping of the pulleys. Time to get these babies milled out of a solid block of AL7075 with a nice black anodized finish.
eheh, thanks for the feedback. I’m showing step by step the progress, don’t see this as a tease. I’m now wondering if should go dual diagonal or dual rear. Probably dual rear but still don’t know what motors, kv and so on. Probably 190kv or maybe 150,
I was thinking with the area rf1 because they are much smaller then the surfrods.With the DH 176mm I was gonna go duel ying yang style single front and rear… as I’ve learned from high power rear wheel will spit you sideways when loosing traction in a corner under throttle I don’t have this problem with my high powered one wheel …it will spin but won’t throw me sideways like a muscle car does…or hit a crack or bump full throttle in a tuck on the front truck and it will spit you sideways or the big wheels start bouncing in the back …wheel hop then spits you sideways…so far I’m thinking front and rear with 150 or 170kv for more torque for bigger gears and 12s is just under the 60k rpm…I think 190 kv is over 60k erpm at 12s … 18t motor and 32t with 78 mm wheels this should get me close to 60kmh 35 mph area I think
