actually looking at your setup again, I would say that you have enough space(right of the bms) to connect your esc using the xt90. BUT the way you have connected the output of the battery to the 2 xt90 connector doesn’t seem right. they should be connected in parallel not in series.
Well today was the first day I got to ride my board. After 3 months of work and buying shit on eBay and waiting.
Despite the (temporary) Velcro straps (because I don’t want to undo and redo 10 bolts every time I want to adjust my vesc settings until I get them right) and despite the deck being “backwards” even though it’s symmetrical anyways, it’s done. It’s beautiful, powerful, and completely DIY.
Still need to wire in my battery display panel and some small things but I went for a 5 mile cruise and I can’t believe the difference between this and my cheap hub motor board.
One issue I seem to have is ground clearance with the @Boardnamics motor mounts. With 90mm wheels I have maybe a centimeter of ground clearance between the wheels under the truck.
Not a huge issue, but I’ve scraped a few times on driveway entrances and small cracks. Roads aren’t the best here.
I’m assuming my only option to make this better is larger wheels. Can anyone point me towards best wheel option 107-110mm urethanes with abec style cores? I’m assuming electric flywheels are the best choice here.
I also am on the lookout for 32 teeth wheel pulley stl files so I can get more speed. I could deal with less torque since I don’t weigh much.
The screw on the clamp should be facing the other way, head facing the ground. That will help reduce the stickout. I also remedied this further by using button head screws which are a bit flatter.
Finally got the chance to ride it! It’s an awesome deck for a build. Your feet really lock in. I currently have my trucks top mounted, but I’m going to see if they will fit drop thru to get more stability
Should mention that my @danile fishook remote did not work out. Must have been something with my soldering but when I went to program it with the vescs I could not get a readout. I will try again but for now I am using a mini remote. Other remote options are welcome as I definitely prefer a thumb throttle.
