Starting this thread now since I’ve got a good amount of the parts coming in and still need help with a few tips and suggestions. I won’t be able to see how everything fits together until I slowly get more parts in.
I got this deck in my Landyachtz mystery box and I’m not 100% sure I can use it for this build but I’d like to try. The enclosure choice will be a challenge and I’ll have to use risers for sure.
For the battery I was thinking about doing this high powered 10s lipo with bms
I also need to choose a VESC and I’m hoping to find a good balance of quality and affordability.
Don’t buy the 4.20, the 4.12 and 6.6s are quite good I believe. Some people have had to run different firmware on the 6.6 though as it would have momentary cutouts
Just so you’re aware, there is a dual 4.20 plus. Its more capable @ 10 and 12s. One member here has been running it 50/50 with no cutouts. I have a feeling all they did was change the caps and add a smart antispark. Trying to figure out what caps they used so I can change mine and be a plus lol.
Just add some extra maybe. I added an extra 13800uf of caps to my TB vesc since I run at 12s and was paranoid of frying them. They have been perfect since
I think he meant the extra caps lol, @xavier I pulled them out of a broken audio amp, they were about 960uf each if I recall, or something like that. A little bit big, smaller would have been better but I’m fine with it cos they were free
Just make sure they are at least rated for 63v, I think that’s what mine were, although higher is always better. Also avoid Chinese ones, they sometimes just get a tiny cap and then put it in a big shell lol
Now I just need
2x 16t 12mm motor pulley
Battery (still deciding Lipos or just purchasing 10s3p Li Ion)
Vescs (probably two single flipsky 4.12)
Enclosure
The journey continues. Hope to wrap this up by spring/summer
