What configuration is the 10s4p and where is the bms? This is 12s4p.
The pack is a 10s4p flat pack and it fits great in this enclosure. It’s actually a bit smaller than the 10s3p NESE pack. Trying to decide which to use.
Excellent. Got any test fit photos?
When I get home tonight I will. The 10s4p from Psychotiller came with one of his enclosures so I may use that on a different board (probably off-road board) and then use the NESE pack for this build since it fits nicely.
10s3p NESE versus Psychotiller 10s4p
And here is the Psychotiller battery in the enclosure that came with it. I think I’ll use the Psychotiller battery and enclosure for another board and then use the NESE on this one since the first is better.
Crazy to see everything finally coming together. I finally caved and decided to go the glass frit route. I ripped off the grip tape on the switchblade and what do you know? RED AND GOLD. it was meant to be
Waiting on two Flipsky 4.12 Vescs and a second 2.4ghz receiver and then it’s just assembly time
Will update once the final parts arrive.
Awesome build! Love the switchblade one of my favorite decks. Locks you in so nice. How is it for an eskate build??
Dope. Nice job.
Good to see you’re getting closer. Just been eyeing this one up to see if it would work out. With a bit of vigorous sanding it should be ok…
I will know once I get to ride it finally
Whatcha sanding? Near the wheels? That looks nice. I may be using that switch eagle I have for an all terrain build
Yeah, at full lean it would bite so minor surgery would be needed. (To avoid minor surgery)
I have a feeling I’ll be modifying my switch eagle a bit for AT wheels. Not gonna start a build thread for that one until it’s done though.
Second remote receiver, Vescs and glass frit all arrived today - these are the final parts! Now it’s just assembly from here
Glass frit is done and looks great. Next up is just figuring out how to fit everything in and make it look pretty… Struggling with it a bit and trying to figure this out… any tips on cable management and streamlined wiring of components? Using two single vescs seems to add a lot of extra wires.
Cut it and solder as needed.
I wish I was better at soldering haha
The sideways soldered xt connectors may really help me so thanks for sharing! It’s like a puzzle
Any tips for soldering those xt connectors like that? Sideways on the wire
