Basic Pneumatic Board | Skateshred 41" Drop-Down | TB 218 | FS 6374 | TB 63mm Reverse | 10S4P N.E.S.E with DieBieMS | FSESC 6.6 | 6x2 Aliexpress Pneumatic Wheel
Haha. Not just printed them, but designed them. I was basically saying that I didn’t take into account the diameter when filled with air, while designing the guards.
So have been riding in light rain and so far no water inside. My approach was 2 fold.
  1. use a thick grease that acts as a seal
  2. hot glue the edges.
I opened it after the third time riding in rain and didn’t find a drop inside. My plan is to check for water in enclosure using a humidity sensor. I think I can interface one with DieBieMS. @JTAG, does it already have a humidity sensor? I saw something in the DieBieMS tool. A quick search gave me this
IMG_20190218_012828 IMG_20190218_011230 thick grease image hot glue on the edge. Easily removed by spraying isopropyl alcohol.
With the new VESC firmware you can input your gearing ratio and the tire dia and get speed distance traveled and the wh/km. Of course if the true tire dia is a bit off the distance would be a bit off too. I entered my tire dia as 155mm(measured it to be 158mm when filled to 72psi) but still the distance is a bit overestimated. Could also be that the true distance moved is higher but the lack of fine grained accuracy of GPS smoothes out the path giving a lesser distance. But it’s negligible so I’ll let it be.
Screenshot_20190219-044525 Screenshot_20190219-044259 Screenshot_20190219-044254
Just a log from today. Screenshot_20190221-124921
Also new covers printed and painted. A bit more aesthetically pleasing design. They are made to fit the TB clamp with 4 grub screws. I had 2 extra ones after I got the updated clamp from . Instead if buying those clamps, you can just 3d print a similar one. The files are available in the thingivere link available somewhere above.
IMG_20190221_014600 IMG_20190221_014744 IMG_20190221_014525
Got them installed. Looks great and no more scraping sound. The TB clamps are overkill, will be substituting them with 3D printed clamp. You can find them at https://www.thingiverse.com/thing:3392881. I have not uploaded the latest files though, yet. with_mud_guards_v2 IMG_20190221_233749 IMG_20190221_233502 IMG_20190221_233551 IMG_20190221_233620 IMG_20190221_222704
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words/2992/9823?u=mishrasubhransu
The wheel guards look amazing! Really nice work.
Thank you. Helps to have everything cadded up and then I can try different looks.
I don’t trust you. Your work space is way too clean.
Haha, that’s my esk8 photography space, so there you go, no reason not to trust me. And of course, workspace is messy.
:scream:
Drooling with envy.
You have a picture of the entire space?
hows the handle holding up? dont really expect such a thin 3D printed piece to hold up
Thought it was aluminum at first!
It’s been absolutely great. Have been using it daily for almost a month. Was annoyed to lift and carry the board before I made it. Especially because my hand would get dirty from all the mess stuck to the bottom and also weight. With this you get off you board and carry it around like a trolley, even works on stairs.
I printed it in PETG, it’s hella strong. Check this out.
No particular workspace. Just Uni’s workshops.
I wonder if something similar reverse mounted could work as a simple binding on a drop-down deck. Here’s a quick sketch.
absolutely, but it’s absolutely not needed because the combination of pneumatics and deep drop(that you can place your leg against) makes it super comfortable. I used to have bindings on my 100mm mbs board but not on this one. Heck, I don’t even need a grip tape. Plus you get a clean look without the bindings
I can imagine it’s super comfortable and I agree with the cleaner look. I sometimes do miss the bindings on my EVO falcon though, especially when riding in a city. The turning radius is often insufficient and there’s no kicktail. On my MTB with the MBS bindings I can easily lift the front and rotate on the spot. On the falcon, I have to get off the board. I think a simple binding would fix this. It would probably also allow me to turn more aggressively.
Or maybe I just need more practice. :slight_smile: Sorry for taking your thread off-topic. If anyone wants to react, I suggest we move the discussion to this thread.
That’s absolutely not a problem, going off on a tangent is my thing. Haha.
15509828532096816023351575311922 First time riding in rain after fitting those front wheel guards on. They perfectly do their job. No throwing off water on me or underneath the board. But couldn’t continue riding because my left shoe(I ride goody) and pant was starting to get went from the spray from rear wheel. Really annoying. Can’t wait to have the rear ones done. They are a bit harder because of the motor mount.
I printed a small slice for the rear wheel guard and it seems to fit well. Printing the whole piece now :crossed_fingers:
IMG_20190224_050239
IMG_20190224_150310
