Fuq! My motors arrived today. I lost my patience Can you add some holes so I can add a pulley cover later on?
Waiting patiently on mine thanks for the affordable mounts!
good lookin out, kevin!
Making progress
trying to figure out what belts I will need. Going to be running 36t wheel pulley and 16t motor pulley. I tried to do some searching. Whatās the best way to figure this out?
I run simulations on a program from Gates to find the right belts. The 320mm I include would work great for that ratio
Didnāt even know you included belts! Nice, looking forward to getting the mounts. What size width are they?
Use this, he has the center distance at 70mm Ā± 8 which Iassume means you can adjust it that much https://www.bbman.com/belt-length-calculator/
I never accounted for an idler so that link getās thrown out the window if youāre using one.
12mm. Some people swear by 15mm but 12mm works just fine especially with an idler
Ah I am going to be using standard caliber II trucks so the wheel pulleys I 3D printed today are 9mm. Hmm.
Iām planing on using dual 6355 with 15mm belts on e-calibers. I was told this would work fine on another thread. Regular calibers Iām not sure. I am gonna be using bolt on pulleys so that probs helps.
This says i would be good with 275mm length belts hmm
Because it doesnāt include idlers into the mix which take more belt length. Both the idler and non idler would work though
Oh I ordered the non idler version so I guess 275 would be more accurate for me maybe canāt wait to get them! Cheers
Yay! Made a fixture and can now mill both sides. This means there is now a chamfer on all edges so they are super smooth and shiny!
wow nice. Does that thing look like the ādiamond cutā like this?
Yep. Really adds to the look. Itās way nicer in person. This also makes my job easier cause I no longer file them by hand.
Damn these are clean looking.
I want to take the surf rod trucks I put on my Riptide and use them for my upcoming Redember deck.
Thinking Iāll go with some calibers on the riptide since its a budget board.
Mounts look perfect.
Works with 50xx motors too?
Yeah the idler version and non idler work with 50mm motors. Still have to make a fixture for the 50mm arm (without idler) for chamfer
