Cutting the first prototype tomorrow.
you never sleep
I am now…its only 1 in the morning!
Matrix II mount done. Everything is as expected. Photos of the raw prototype:
This thing is BEEFY. Seriously…the motor plate is 8mm thick, clamp 12.7mm. maybe overkill but it’s very strong! I like it
This is awesome
No such thing as “too strong”
gib
Also, do you plan on making an idler version?
How do you fit the motor pulleys with a thick plate like that? Will it have to hang partly unsupported over the end of the motor shaft a bit so it does not hit the plate?
That’s for the guinea pig to figure out ;).
It is 2mm thicker than my standard mounts so that shouldn’t pose a serious problem.
Idler maybe. I am not familiar with mountain board setups so I need to get a mock build going before I can design for that. The idler has to clear the wheel.
What Janux does is the idler is machined out of aluminum and rides on a bearing; it’s machined in such a way such that the bolt head is completely recessed into the idler. What I don’t like about it is that there’s no bearing between the idler and the mount, though.
I envisioned a good idler as, similar to how Janux did it, but also is recessed on the other side to ride up on a second bearing that sits between it and the motor mount.
Come play Apex
Hah loser I’ve got a 23% in calculus You wanna help me with my homework?
I got a 2/100 on my last test lmao
I aced calculus, let me do ur homework so I can get my mountainboard mounts faster :P.
send homeworks
(and motor mounts)
pl0x
Yes, it’s not going to be a problem I was just wondering if you solved this somehow as I experienced this myself. Some of the maytech motors have so short axles and I like having a circlip to secure the motor pulley. Better to get motors with longer shafts I guess.
Yea that is what I would do. I am more worried about idler placement more than anything. I am working it out rn.
What belts should I get for a 18/36 ratio and your mounts?
