I don’t know to explain it clearly, but TB pulleys only use bolts to connect the pulley to the wheel, so when tightening them, you have to be very slow/precise (it will take you many tries to align it).
These pulleys already have the pillars (I don’t know how else to call them), so when you inset it into the wheel, it’s already aligned, and the bolts are only there to keep it from falling off the wheel.
I see. I was confused because originally I thought these wouldn’t need the outer bolts. Which is asthetically preferred for me. So I was confused when @Deckoz mentioned bolting up.
But it seem there are no bolts now as I originally hoped:
Still curious about the inner bearing. Wondering if it’s an additional bearing or if the pulley seats it’s self where the inner most wheel bearing is normally seated. And wondering if it’s normal skateboard bearing size or if it’s bigger like the boosted pulley.
Don’t get how people took Black Pigment == Wheels Chunking.
DIYE Rebrands like Meepo advise against their Red Wheels, probably because the red pigment and their formula don’t work well together. It’s not something only said by Boa
Any mention of black pigment being an issue was in relation to our wheels and NOT a general statement about all black wheels. People seem to have misinterpreted this.
“Introducing the Boa Black Belly ceramic bearings. Featuring a silicon nitride ceramic ball with nano ceramic grease as standard. These bearings are corrosion resistant and are treated to withstand salt and harsh conditions that they will endure over their lifetime. Fully sealed and with inbuilt spacers and speed rings! In stock and available for shipping next week.”
