I was putting together my first DIY esk8 with the Torqueboard mounts and I’m finding the ground clearance a little low… does this look low to anyone else? Or am I being paranoid?
I can’t raise it any higher… the next possible position would be way too high.
That’s too low… unless you get rid of the riser in which case it’s reasonable. Alternatively, add another riser. Or just rotate the motor so that the wires aren’t a problem and then you’re good to go (most likely)
@Erod - We have a reverse mount if you want to mount in reverse. Out of stock now but should have some in on Monday/Tuesday. Reverse mount will also clear the baseplate.
Yeah that’s what I thought you meant at first… but the motor wouldn’t fit that high anyways, the trucks are in the way…
BUT I still moved the trucks back 3/4 inch to the rear and I think that’s going to work non-reverse… Just need a slightly higher riser… so thanks for the idea!
