Do you know if the “Core” is excactly the same as the Kegal ?
Could a Kegal wheel pulley fit onthe 90mm ?
look like it
Sneak peek at the New Raptor 2 Battery form factor.
We developed custom 18650 cell holders that provide additional structure to the pack and also protect the welds. This makes pack building much faster & results in a very compact unit with high energy density, whilst also offering simple user replaceability.
All of the battery control circuitry is sperate from the cells, so swapping switches and replacing parts is very quick, minimal if any soldering required!
Here is a quick test video showing the Raptor 2 Motors, running Sensored FOC - Super QUIET & TORQUEY
Who made the video? Thanks for the update on the hubs!
some hub road testing, i’ll try to do a better video over the weekend if the weather permits… could only withstand so much cold.
Haha cell phone shut off because it was too cold …that’s sick
Acceleration test
At the beginning it’s not cogging, it’s skidding and shooting rocks
0-32km/h under 5secs, after the bluetooth connection was lost
185lbs rider
That is really good considering the temperature outside.
Booger freezing cold
I just checked the video, the temp is off by about 15 degrees C, the temperature was -15degC. Guess the sensor is not linear at those temps
In your acceleration video, how much much faster were you able to go after the video cut out? Basically asking top speed in extreme temperatures.
I went up to what like felt under 40km-h, but i would like to have gps data to back that. Even at that speed it did not feel comfortable (safe) with all the rocks and salt on the streets
On the bench top speed in foc was 41km-h, in bldc was 45km-h. Might suggest to @onloop to up the kv a bit, these guys have plenty of torque. I was fully braced for the acceleration and still slightly lost balance.
The dyno should be in in the next couple of weeks, that will set a good bench mark
Wow that looked amazing! Are the motors going to be developed by enertion or are they going to use the motors from someone else? This is the first time I see a hub motor accelerating as fast as a belt driven system
These motors are unique to enertion.
Are you going to offer a softer duro wheel? I’d like a 75A to go over infinite bad roads on my country.
They will be 75a.
That’s awesome can’t wait to get my board.
I wonder what number of backer am I. I’ll be nice to have a board number for each backer.
Great job!
hm, that acceleration looked pretty impressive, I bet I could easily get away with just one of these in my flat area
and 75A 90mm hmz, sounds like a great package. waiting for the day these will become available without a board-bundle
Just buy 1 and change the deck.
