You can wire batteries in parallel to increase the current output
parallel wiring increases battery capacity current output = capacity * C (discharge rating)
For me it’s about demand. The better amperage you can deliver the better throttle response.
Am I the only one having problems disconnecting an xt90s. My xt90 is very difficult to undo. Any fixes for this?
I have Noob Question. I bought 4.12 vesc from Enertion. I have 10s li-ion battery and sk3 6374 motor. Can you write step by step guide what I need to do next?
This forum really need step by step guide for beginners. Here is good threads all around this forum but nothing like this. And is should be pinned.
Name would be: Esk8 build for dummies
Here ya go…
This one is real mess. Clear and simple step by step is what newbies need.
A simple solution is to lightly sand the female XT90 around all the edges. Be sure to use a fine sandpaper so you don’t remove too much material. This video is for XT60 but should be the same idea.
Got another question regarding 18650 batteries and soldering them, I see that some companies, NKON for example offer to solder U / Z soldering tags on the batteries before they ship them. The strips on the tags diemensions: 30x7x0.12mm.
Isnt it a possibility to decrease the heat transfered to the given cell that you get thoose tags and solder onto the tags and somewhat decrease the possiblity of heat getting into the battery?
For someone wihtout a Spotwelder this would be as soild idea? or is the tags themself gonna heat up when battery is in action due to being to thin?
I’ve been doing some reading, but still don’t really understand sensored vs unsensored motors, and where does the sensor wire connect? What does the sensored aspect of the motor do exactly, and can you run a sensored motor without using the sensored wire?
search for wiring diagramm, there are a lot of good things online here
there are a few people here soldering without a spotwelder. You´ll need a high wattage soldering station above 80W to solder as quick as possible. Also there is this method:
I know how to wire everything. The big question is: Can I set up Vesc with the 10s batt for the first time? (Enertion 4.12 Vesc)
There you´ll find everything you need. If you have any specific questions and can´t find them anywhere just ask
Some people say that I will be fine, some say that I need to set up it with low wattage power supply. maybe you have suggestion?
normally there shouldn´t be a problem, because they already did the first setup for you. Some people get one without it. If you wanna go 100% sure, use a low voltage solution like in this thread:
I been searching around for a switch and came across the angel light.so I look up forms for it and really couldn’t find angrything:disappointed_relieved: but anyway I want to use it on my set up like the picture . The set up have is is 4*35c 14.8v two are connected in parallel then connect in sieres
I think if you´re talking about an “Angel light” you like to have a LED switch? Something like this: diy-electric-skateboard-kits-parts/electric-skateboard-on-off-power-switch/
I’m starting my first esk8 build and I’m thinking of the following components.
Ollin vesc/heat sink Diy motor mount Torque boards 6374 190kv 10s battery Diy 16/32 pulleys 255mm 12mm wide belt Gt2b remote Caliber2 trucks 184mm 10in 83mm flywheels Bustin modela 33" deck IMAX b6 charger
No hills in Myrtle beach where I’m currently living any feed back would be appreciated
