Can someone please check over this lost and make sure I’m on the right track? Im still new to this all and would love some guidance/suggestions. FYI I’m running the 6 cell batteries in series, Thanks.
no, the turnigy has a round shaft so if you put a pulley with a round hole on it, it wont hold in place = it wont transmit the power of motor…thats why the enrtion motor pulley has the smole square hole in it (http://www.enertionboards.com/electric-skateboard-parts/12mm-wide-drive-pulley-kit/) as you can see on the black motor pulley…then tere is a small iron block you put inside the pulley, but there must also be a hole in the motor shaft, so the block fits between motor pulley and shaft of the motor…it “connects” the motor pulley with the shaft…ASUFHAOiufnh I cant speak English that well to explain this I hope u get it, if not I will send you some pictures to explain that
shaft key is the small thing you put between Motor pulley and shaft of the motor
The Enertion motor pulley has a slot, where you put a shaftkey in, which you´ll also need on your motor shaft. This keeps your motor pulley on your motor shaft.
SK3 motors do have normal shafts without a keyway, so if you want that technique, you have to file down one side of the motor shaft. You´ll find a tutorial around somewhere here for that.
The other option is to glue your pulley to your motorshaft with 648 loctite. That´s what lot´s of people are doing.
The programming is really easy guide: https://www.youtube.com/watch?v=EkqrZTeoQuk&list=PLICpQdAXJazT-ICMIgJuc2pl-w0-j1j9A
VESC-x should be good, but if you want to spend some money, you can go for Maytech VESC (cheap, chinese, sometimes comes without frimware - then you have to really programm it and that sucks) or DIY’s (they would have to ship it from the USA, but it is quite cheap and still reliable)
IDK if there are any autralian vendors except enertion, maybe you could get one used from someone on this frum
Buying from somebody on here is a good idea, I just really don’t want to spend $200 on a vesc, I still don’t understand what the difference between a good and bad vesc/esc is
