I’ve had quite a few sessions now and getting to know the board quite well.
So, from the ground up…my thoughts…
The 80mm Oragatang wheels are great. They do a great job of tackling dodgy pavements and steps of up to 1/2" or so.
The durometer spec is perfect for grip, wear rate and ride comfort.
Big is best, for hacking around on rough streets, so some 90+mm FlyWheels would be better still IMO.
The Mindless Talisman trucks look absolutely stunning.
They have a lovely feel but I suspect they are slightly softer than an ideal esk8 choice.
I adjusted the bush compression considerably and this much reduced the sensitivity and thus the tendency to wobble at speed.
However, the lipped washers started chaffing on the hanger so I had to relieve the lip a little to allow that little bit of extra adjustment needed to get them just right.
The 3s 5000mah Zippy LiPo’s are great batteries.
They seem to serve me well with my other interests so seeing as I had them already, happy with!
I do, however, look after all my Lipo’s with a fanatical approach.
I never store them fully charged and I never over discharge them.
Anyway, there’s plenty written on LiPo care so…moving on.
The EzRun ESC. Works perfectly and never gets beyond warm.
I reckon it’d probably be OK without the fan, which would reduce it’s profile considerably, but maybe another time and with caution!
The only negative point with the ESC is the well documented screeching noise it makes under braking.
Certainly makes you think about slowing down early so that you don’t have to use it, especially if there’s people around.
The voltmeter…perfect in every way. Lets me monitor exactly what state of discharge the LiPo’s are at, as I ride. Essential in my book.
The home made deck? Mmmm, not nearly strong enough, made with the materials I used. The Vanguard shape is also a little uncomfortable for me. I now believe commercial decks are good value so probably wouldn’t make another. Even the £20 ebay ones are better than I can produce so I’ll leave DIY deck building to the more talented among us.
The 2.4ghz controller? For £20 you really can’t go wrong.
It would benefit from a good hack and rebuild to make it smaller.
Something for the future.
So, I’m riding along and I hit a ramp in the road where the tarmac is out of level.
A loud crack noise comes from the rear end of the deck but all seems ok.
When I say ok, if I’m honest, it does seem a tiny bit more bendy at the rear.
I decide to order a cheap maple deck off Ebay to use for prototype 2 as this deck’s days are now numbered.
Two trips later, and out of no-where, my deck suddenly snaps on me while cruising on perfect smooth pavement!
I step off easily and quickly but I’m pretty gutted as the beautiful SK3 motor has briefly served as a wheel and in the blink of an eye, it now looks 20 years old.
Here’s 4000 words worth of pictures as writing about it is painful.
Ah well, that’s christened it as they say.
I’m now up and running again with by new Ebay deck.
It’s a great deck really and very comfortable.
So that brings the tale up to date.
As soon as we get a descent day I’ll take some more pics and do a little video of it in action. I have a few minor improvements in mind which I’ll bring to the forum but for now I’m gonna get some miles on it.
Cheers for now.
Hopefully a video in a few days.
