What is the motor max rating of the Jacob hub?
0.2mm thickness japan stator 24 slot N48SH high level magnet 28 pole Original Japan NSK ball bearing Max. volt (each ): 6S (25.2v) min. and 12S (50.4V) max. Max power (each ): 3000w Continuos power (each): 1500w Max. amp (each ): 60A Continuos Amp (each ): 30A Wheel dimension: 83mm63mm57mm Dual Hub Motor 3000w: recommended for people up to 220lbs
You wrote “1. All stainless steel hardware” What do you mean with this? I believe at Jacob’s hubs there is no stainless steel. The rotor should be normal steel with chrome and the other parts are made of anodized aluminum. Did you change the materials?
Right now it will just be the set screws and the bolts holding the caps.
I’ll look into machining the caps in steel later on
Hi @ralphy, I’d be keen to get some of your red thane. Just to confirm - no need to add the extra nubs or use the insert?
Also, do they make matching red front wheels?
Jajaja well thanks that what my students say all the time. Sometimes the most comolicated issues are the simplest to solve. Glad to be here to help.
So pricing some people have asked questions, price is fixed as follows
Base setup is $335 for dual motors with upgraded Stainless steel hardware and silicone phase wire leads shipped within the USA
Extreme setup is $150 more includes everything in the base setup plus the added high temp rigid sleeve insert bonded to the urethane wheel and nubs installed with lifetime support for replacement limited to 3 exchanges
International shipping starts at $35.99
As I said 15% of all sales will be donated to Jacob if he wishes to accept it
3d print knubs and sleeves are available for 19.99 shipped in the USA and it will solve your slipping issues with the current stretched out urethane you have.
So there you have it 3 simple solutions to the issues ranging from 20 bucks to almost $500 to make you a badass e boarder with the most powerful motors manufactured to date.
Items have already started shipping
Paypal [email protected]
Hey man, That’s damn decent of you to help jake out like that man. This community has some really stand out members. Thanks for that.
Thanks I really believe in giving back, its yielded excellent results in my life.
Jacobs coming back!!! With some great initiatives so let’s all help him bounce back from his financial setback collaboratively.
Who’s in?
If there are great initiatives and a little bit more communication I think quite a few people would be in. Communication is key though!
Is there a package price as per Jacobs original $299 listing to include front rear mounts and front wheels?
Are you offering shipping to europe?
The red urethane was just something that was done for id purposes during testing. The urethane compound first batch will be produced in blue although i said black might be more popular.
An easy way to identify its the better rubber is to squeeze the wheel in your hand. The good one will hardly compress when its off the motor.
The upgrade urethane will be extremely affordable.
I cant do the original price because the process of purchasing receiving repacking and reshipping does take time and money. As stated before for pricing its fixed there are two options and worldwide shipping is available. Just scroll back and read my posts.
Jacob might be able to negotiate drop shipments direct from the supplier but thats between you and him.
This is red soft rubber which failed https://youtu.be/vojzvNTAGZM
This is hard red rubber which currently is performing well https://youtu.be/oB1dfXGx_ZU
i’m in, Thanks Ralphy
Since you’re redoing the thanes, is it possible to get bigger ones? I would like 90mm or maybe 97mm. And in black.
I second that suggestion. At least a 90mm option would be nice.
Not right away but it might be possible
These look identical ~$299 shipped:
Electric Skateboard Dual Hub Motor 12S LiPo www.ebay.com/itm/262582748321
