Sorry someone does not have motor pulleys to print in 15mm 3d
That is because 3D printed motor pulleys do not last. There is simply too few teeth engaged and the forces too high. They wear out far too quickly to be a viable solution to use as a long term part of your build. Luckily for you motor pulleys are very abundant, although not sure about that at 15mm width, but these already exist. I spend my time on things that dont or are niche items that would otherwise need to be custom made. Good luck.
Hi, I have printed a 36T Pulley for my Abec 11 97mm Flywheels and yes they fit, but it´s a really tight fit. In addition the pulley does not close with my wheel, there is âairâ. Are these Pulleys mostly for the 107mm and 83mm and not for the 97mm Abec Flywheels ? I have original ones.
These are a tight fit yes, that helps ensure that they are concentric to the hub which is what you want. With regards to the âairâ between the pulley and the wheel please provide a picture for clarification as that can be interpreted in many ways. These sit flush to the hub/core where they meet the urethane, not necessarily to the middle of the hub where the bearings are seated. If youâre taking about the exterior of the pulley and the urethane of the wheel then itâs not an issue, youâre not driving the urethane youâre driving the hub, extra contact on the urethane is not necessary. If that is not the issue youâre talking about then provide a picture and I can get back to you on that.
107 have theyâre own pulley as they are significantly different in dimensions, if you wiah to see how different then look up the 107 series I made just for them.
These should fit both original and clones though the tolerances may be different from make to make so keep that in mind but once you bolt these on that is not an issue, it will sit flush to the hub and it will sit concentric to the hub.
Okay, thanks. That helped a lot. I thought the pulley would sit flush, so it touches the urethane (learned that word, too :D). My pulley is not perfect round or the wheel is a little bit off center, because the pulley wobbles a bit. Maybe thats an issue of my 3D Printer. I will print a new pulley with 44T instead of 36T to get more torque. So i thought, if it sits their without âairâ in between there would be a better power transmission, but now i´m understanding that this isn´t the case.
Would this pulley also fit for my 97mm Flywheels:
https://www.thingiverse.com/thing:1719951
Because you said in the description " tested with 83mm and 90mm ", but i think this should fit, right ?
Yes it should fit.
does anyone know if the flywheel pulleys work on caliber ii trucks without modifications of any kind? (no cutting/filing etc.)
afraid the nuts will end up hitting the trucks. would really like to know
Been running the 36T pulley with Caliber IIs + 83mm Flywheels for the last 6 months. It works great, no modifications needed.
Awesome. Thanks for the info.
What truck is that? I have the same carbon fiber motor mount as you have in the picture, arenât they only supposed to work on caliber trucks?
I think tracker dart 215, youâve to modify (file down) the truck if you donât use them on the caliber 2.
with Evolvetruck:
Has anyone tried these with 90mm Stickies from Trampa? Do they fit?
Are there any members based in Germany that do prints of these? Iâm helping a friend with his first build. Thanks
Yep, here! But probably too late
hey can someone explain to why when i import these into fusion i have a part that is scaled up? i work in mm, so this shouldnt be an issue, but it somehow always is when i import STL, IGS/Step are totally fine.
Iâve printed 36t and 40t 15mm version but they donât fit in a 97mm black and green original wheels⌠Pulley is a bit oversize and its necessary press hard and they tend to broke. Anyone was able to fit in the reflex version?
I have a problem to bolt down the pulley⌠the holes for the hex nuts are M6 but the screws are M5⌠any change to fix this?
ABEC11 40T pulley.
Can you not use M6 bolts? Those fit in the flywheel hubs better also.
