i solder everything. 5.5mm bullets.
Any one living in Germany have surplus bullet connector 5.5
I’m in USA
I have 5.5 bullet connectors.
Hobby king with quick delivery will be the fastest way to get
Germany
10
I just got butt crimps w heatshrink n a crimper that got good reviews on amazon. I’ll do some resistance testing and comparisons w other connection methods. Such low resistance need to use ohms law n two miltimeters. A solder joint is as electrically conductive as if it were a solid uncut n soldered connection if it has an overlap of 3x its diameter. I’d rather crimp
If the contact is already good then it’s just a reinforcement no?
If its a true gasless crimp the solder wouldn’t get in it and there’s also slow flow. With people who have tested solder on top is not as good mechanically
Thanks for that info
I need 6 male 5.5 how much
Doesn’t add to conductivity and makes wire brittle and prone to cracking from movement/vibration
