No worries @Mikaelj As soon as the mounts get here ill get some pics across, im wondering what belts will be best so will need a few to experiment with.
Im testing out the 177 TKP with 110mm shoulder bolts to see how they perform with the TB110’s .
Took me a while to work out the combination on spacers and distance for the crossbar but got there in the end.
I’m using 177 TKP with 110 shoulder bolts with bergmiester wheels.
I have also fitted the Evolve 83mm street wheels with a 36 tooth gear and it uses he same spacer combination so when my TB110’s arrive they should fit perfect
Just a few last bits to finish and I can tear it about
Does 180mm surfrodz exist? To use the second crossbar on this setup you would have to topmount the deck or lower the angle of the mounts. I think this is fine as is, it’s better to have the ground clearance than the second crossbar in this case.
btw, I have around 60kms on your mounts now on my Vanguard Deck build. The mounts haven’t moved at all. I’m so happy with them, it’s the 5th mount I tried and the only one that has such precise alignment and good design that the 12mm belts don’t skip even with no idlers being used and my 220lbs. Nothing has moved out of place either, super solid.
just finished designing this for my lrdesigns mounts. Here are the diameters your looking for. Hit me up on PM if you want anything - I now return you to your regular programming.
