Yeah, ender 3
will it work with the crs10 pro? require a firmware update?
Yeah, will work exactly the same in cr-10. No firmware update. Just needs a different esteps. I changed it in the front console. The thermocouple provided is also the same.
Donât think there is any ideal do-it-all printer although some come close
You need direct drive for TPU really, a bowden is no good.
Best to have 2 or 3 printers, just like esk8
I donât have any experience with them but I believe there is now direct drive with a flex shaft now, light weight head speed of a Bowden but able to print tpu.
Got my octo print set up and BL touch installed and flashed the firm ware on the main board. No more constantly checking and adjusting bed level between prints.
I do notice a bit more noise from the printer. Nothing too crazy but must be from the z axis motors moving alot more often to compensate for the uneven surface.
What slicer and retraction settings are you using? Maybe itâs retracting a lot?
Cura allows control over very finite settings including not retracting if within N mm. Highly recommend, there is a plug-in which allows directly printing to
Sounds like Z hop, which is used sometimes during retracting⌠again configurable
Relocated my maketgear m2 to a smaller locker so my climate and humidity control didnât have to work as hard. Still need to seal the edges of the door and reroute the climate control tubes.
