Once you uploaded the FW, VESC-Tool will recognize your HW and you will only get suitable FW as an option.
For non-default FW there is checkbox below the FW window.
Have to be honest. Vesc tool hype is disappointing. As I can tell it does the same as BLDC tool. Just in a “prettier” interface. Has setup wizards but the one I think is useful is ppm input wizard which ackmaniacs extended firmware already has. The motor detection is more “complicated” as it failed first try, had to adjust voltage and erpm. The motor readings are different from BLDC tool so not sure what that means (I used 10amps and 800erpm?). The control modes are the same. For those hoping for DUTY cycle with neutral it didn’t happen which is the reason I was looking forward to the tool. For reverse you cannot set it up so you have to double tap the brakes to engage reverse like hobbywing escs or one step further like @Ackmaniac firmware where you have to decrease erpm to a certain number to safely start reversing (Extended Vesc-tool?) I have not tried the foc tab.
If you’re use to BLDC tool, vesc tool seems more complicated because everything has it’s own tab. I mention all this because if you switch to VESC tool you cannot go back to BLDC tool without bootloader
Hey Guys just a fair Warning… As stated in the warning at the beginning of the tool it is still experimental… and as not been tested properly by everyone so it might void some waranty… and it seem that you can’t go back to old firmware after, without uploading the old bootloader
I hear what you are saying Titoxd - but disagree on one major point. Simplicity to load and connect/configure a VESC.
Sure, i have a linux laptop somewhere - followed step by step Ben’s guide and it works well. But then i had an issue and tried to reload it… and had issues (like one of the library paths changed)… So then i need to hunt down one of the ported for windows version - which are super specific on what firmware is on that VESC. Except i have 9 VESC now… And only configure one every 5-6 months (once setup - no need ot fiddle w/ it)
So from the simplicity of plug-n-play - i find the new VESC Tool a LOT easier. I’m a linux noob (but in IT - go figure… MS has paid the bills for years and i stick to Windows).
All i’m trying to say is a few minutes in the new tool were a ton easier - wizard driven setup. Info on nearly every button. Explanations of settings, etc. Far improved. If you need to fiddle w/ your amps to detect that seems a small price to pay?
I didn’t like the wizard tbh every page has warnings and popup boxes. In BLDC tool I look at 4 tabs/pages and in vesc tool I have to look at 10 to make same changes. Not a big deal just wanted to mention it.
As for motor detection what is recommended
For amps and erpm and duty cycle
No, it’s very easy to upload “old” FW. In VESC-Tool in the firmware tab you choose custom file and can upload any FW, after upload is done you just need to open the respective BLDC Tool for settings.
BTW I love this VESC-Tool and new FW, already used it in FOC on HW4.12 for 400km without problems.
That’s the only point I’m missing, too… would love to use reverse function but it is too dangerous now.
Exactly! You are not locked!
We strongly recommend to update to the latest FW, using VESC-Tool.
2.xx is outdated and will get no more updates.
Bugs simply get no fixes.
Using VESC-Tool, you will be notified if a new Version is available, which is pretty convenient.
You won’t miss critical updates and new features.
This way you are always up to date. There will be frequent updates available. You can also write feature requests in the corresponding forum section. We will have a close look at this! This way everyone can help to improve the software.
I know that there are many improvements in FOC with the new FW that’s why I gave FOC a try. I’ve never tried FOC with FW 2.18 because I was afraid to fry my HW so I can’t tell you about difference in performance but it seems that FOC is much safer now with the new FW. As said I’m running sensored FOC on HW 4.12 on my dual drive MTB since 400km and fell in love and will never ever go back to BLDC , but I switch to VESC 6 soon.
Thanks benjamin, frank & ted for all the time you spent on this!
