Thanks to everyone who suggested a few things about the pulley motor sitch. I’ll have a closer look tonight when i get home.
In the mean-time. I gotmyVESC! (woohoo)
this one has the newly designed capacitor board. definitely tidy, also the whole hting is smaller than i realized (18650 battery for size comp):
Anyhow, after much tinkering with different size heat shrink, i settled on the hoodrat solution (electrical tape) to shield the receiver connection from poking the leads. I soldiered up the bullets and can’t flipping wait to plug this into my uneven-pulley-having drive train tonight!
The board is assembled and this is the last piece. Hopefully the BLDC tool doesnt suck the life out of me tonight and I can get my maiden voyage in before sunset! Stay tuned
So jsut want to be sure I’m right here. Again, SCP3 and a R-Spec 6372 motor. Ran motor detection and got:
Detection results:
Integrator limit: 94.59
BEMF Coupling: 628.77
Just PPM. Make sure to set the min max pulsewidth settings and rebind if you adjust the throttle trim.
Startup boost is the minimum duty cycle essentially. I’d leave it alone unless you have startup problems in which .05 sounds like a good conservative max.
okay-- nerves have simmered. Beer and vape in hand.
Didnt periscope, but i caught the shit-eating grin on my face within the first 5 minutes of riding:
No, i’m not wearing a helmet. I will. I was so pumped i ran outside with my goddamn workboots on. had to run back up.
Second, i’m astounded at how fast this thing is. I weigh around 185 right now. The board is heavy as hell (not sure exactly how heavy but 9-ply maple is a lot of weight) I hit 24mph and there was still A TON LEFT to go. I pussed out. Maybe tomorrow I’ll see how fast i can go:
The brakes were a bit weak. And honestly, that was probably a good thing for my first ride. I was stopping way earlier found myself coasting ALOT.
I’m lucky enough to have a pretty good stretch of newly-paved road in the neighborhood. I did a little analysis and i find that about 17mph is perfect cruising for wide streets and long flowy carves. Probably slower than I would be going on snow, but same feeling. Amazing.
So anyhow, I guess my question for the community is-- what should I do to try and up by braking power a bit??
Up the motor min regen to 50/60 and dial it back as needed. Only the battery min regen dictates how much is going back into the battery. I’m using -90A (between 2 VESCs) on mine with -16A battery regen (10s4p)
like the colors, raw trucks & silver mount is nice! did you test the board in the shop and then order it at amazon? i would really support local stores for giving me the chance to test things. wish i had a large skateshop around …
