hi. unfortunately i am not planning to make a 200A anti spark
but could you pls describe your build(motors, battery, esc, mountainboard/longboard)?
hi, is not a skateboard actually, is for a boat motor because i couldn’t find anything better anywhere. In case you change your opinion on making a big one, reply me. Thanks!
hi interested in this do they get hot do they need a heat sink, also are the switches latching or momantary?
hi
no, they do not get hot if the current is not higher as the switch is rated for.
switches are momentary
smaller 3 mosfet anti spark (pcb - 58x27mm)
up to 75V, 70A cont, 360A max
worldwide shipping with tracking number - 4$
other anti-spark switches:
Where do we order
info in PM
Anti-spark with key switch and led indicator.
Up to 75V, 60A cont, 360A max
Worldwide shipping with tracking number - 4$
hello I would also be interested in a spark protection for my efoil, My configuration is 12s, VESC 75/300 Could you send me an offer via pm?
info in pm
Hi there, are you still selling the switches? If yes, I’m looking for one for my eboard - Dual vesc max 100 A continuous and bat is 12s. DM me whenever you are available.
Cheers, José
hi!
yes, i am still selling the switches.
info in PM
Hi all, hi eLDoska,
First of all, I’m acoustician, not electronician (low skills), I did not plan to produce and sell AntiSpark !
I love DIY, so using my little cnc, I have made my first PCB for an AntiSpark, that I’ll use in my future projects.
I’m currently on a ESkate and a BoomBox for friends.
ESkate : 36V, 30A, 9.9Ah (10S3P), dual hub, 2xVESC 4.2.
BoomBox : 48V, 30A, 9.9Ah (13S3P), dual amp, DSP, BT5.0…
Using a Software, I have draw this schematic to get a PCB that I can mill :
The V1 is from the “automatic” PCB maker and the V2 is the same I have re-draw :
The V2 PCB, much more simple ! :
Well ! First tests done @24v, 3A (lab power supply) with a 24v light bulb as a load.
Work perfectly, On, OFF, ON, OFF… Perfect.
But, I have an issue and need your help. (Same thing on V1 and V2…)
The second test I have done is with the BoomBox battery @49V charge.
Battery->BMS->AntiSpark->Voltage regulator->Amplifier->Speaker (not on the photo)
Switch OFF, I connect the battery to the switch.
All is OFF, good.
Switch ON, all turn ON, good.
Switch OFF… It doesn’t switch OFF.
One of the 3 Mosfet stay closed.
Same after 2 more tests.
Did someone have an idea for me, I have low skills in electronics, I’m learning on every issues ?
Should I add a “big” (how big ?) Diode to help the freeweel of the Mosfets ?
Or the problem is located on the Gate ?.. No idea… I need to understand !
Thanks for your help
Edit 1: Sorry, can’t post photos…
Edit 2: No link too… dunno why…
There is a “link” (add a H first): ttps://drive.google.com/open?id=1TKHm4nMjUXa6Gy_Gc_AsGyMxDTigYueQ
Brother, this forum is in dirt nap mode now. Come ask this on the new forum and we’ll get some smart dudes in your corner.
Hi, Where is the new forum ? Thanks.
Never lose your wit Bill, absolute gold across both forums.
Hi
I’m looking for a 100A antispark switch for 14S battery. Do you still have one in stock ?
hi! sure, info in PM
I’m having shit luck antispark switches from online retailers with my 10s setup. Yours look solid, are you still selling them?
