Just wondering if the vesc I plan to buy will work with my batteries and motors. I am pretty sure it will but it’s my first build so I want to make sure.
That motor has 4mm banana plugs. The esc has no plugs, you will have to solder your own, same for the power. Running 10s I would change out the connectors on the motor for 5.5mm bullet connectors myself.
Pretty sure 4mm connectors are fine; heck, Enertion even do 3.5mm for their ESCs because it’s been tested to be a non-issue. Wish they used 4mm though just for better compatibility…
