First post on the site and first build in progress.
I currently have a Trampa Holypro with vertigo trucks, hypa hubs and all terrain tyres. I weigh about 75kg and will be using this board mainly offroad.
I have ordered motor mounts from Idea on this site.
I’ve also ordered a Focbox Unity which should be arriving in January.
Any recommendation on a battery for the above, I was thinking a 10s4p. Ideally the battery will be prebuilt (square) with battery screen, charger, BMS and switch if possible.
What do you think of my motor choice and battery?
Also any recommendation of where I can source a prebuilt battery as above.
10S4P is imo a bit small. Normally people do 12S4P as a minimum, but something like 12S6P+ would be better for a offroad build. It mainly depends on your desired range, power output and budget.
