Hey Jenso
Making my first post and I’m almost done with my build, thanks to your help. I have 2x sk3 Turnigy 6374 192kv, should I go for the 9100-12 or the 9120-12 Roxxy?
Cheers
Hey Jenso
Cheers
Go for the 9120-OPTO, dont cost that much more… make sure you get some additional CAPS … like the YGE 9 Caps Cheers
Hey Jenso!
Do you recommend the Roxxy with cap bank as a good upgrade from the Max6 ESC?
Is there a big increase in power from 8s 150A to 10s/12s 100A?
Thanks!
I think its alot more powerfull… But the brakes can be hard to get on with… like i mentioned from DAY1 with the Roxxys the Brake way is so short that you really need sensitive fingers
Cheers Jenso
Does it worth having 120A continuous (9120-OPTO) more than 100A continuous (9100-OPTO) if the SK3 brushless motor is rated 70A max?
I’m thinking of buying one of these ROXXY ESC too.
I never thought about the smaller ones… this 20€ less dont seems interresting for me… Some people i know are ok with the Roxxy, other dont… Its a beast but power/brakes are hard to control
Hi. Could you, please, tell me what are your cap bank specs? is it 63V 3600f?
YGE caps type 9, let me find the link for you bro and i’ll edit link and specs: Modul Typ 9 • 9 pieces 390 µF ultra Low ESR Elkos • Operating voltage: Max. 63V (bis 15s LiPo) • Solder bucket for cables up to 8 mm² • Measurement: 23 x 66 x 33 mm • Weight: 42 g
Thank you very much!
Also if you pour it all over electronics it wont be able to catch fire because there is no air, but cooling might be a problem
What were your thoughts regarding your previous config with the 149kvs vs the 190kv sk3s @Nowind? About to pull the trigger on a pair for a 12s emtb setup with focbox Fairly long hills in the commute, your 80 degree coil temps make me think maybe the lower kv will be better for me
I would go for the 149kv… better for torque and temps… also your vesc will be thanksfull for not hitting the 60K erpm limit…
EDIT : read anwhere that the Focboxes dont have the 60k limit… more around 100k erpm… But anyway i would choose the 149kv…
Cheers
