Only a few small sticky spots on top so decidet to take it out of cast…
I was a little bit brutal, get it out but damaged it
A big crack runs trough it …
Fuck yeh Jesso, doesn’t look to bad as long as it works that’s the main thing… Plenty of time to fix aesthetic things… Maybe put some food die in with the resin to make any colour you like.
@bbq870
Its build originaly to compensate longer battery wires.
Every ESC Builder will tell you that you have to use as short as possible power wires.
If you cant do you are supposed to add this capbanks… they are some manufactors like YGE and MGM who are selling this for their ESC´s. YGE also says that they will improove the “partial load” property and that this capbanks should be used if the ESC is used on its limits, like max voltage…
So i think it is really made for my kind of application (-;
Got only 3 rides now on the moded roxys, only time will tell.
Yeah really easy to add nearly any wanted colour. R&G is selling many differnt colours. I dont use it this time because i dont want to cover the LED. But its easy to add an piece of Polycarbonate on that LED to take the light out of the cast. Maybe next time (-:
No Firework yet. Only a bigger ignition Spark (-;
But dont forget that the un moddet Roxxy performed well for several weeks until they explode.
So it took some time to say that the Capbank will improove them !
Yeah the MAX6 are BULLETPROOF without ANY mods
No probs with heat and moisture
No with vibrations and dirt
No with high current or “over current”
Just have Fun and dont worry about.
Good to hear that the caps are doing the job👍🏻 I’ve eventually got my build progressing which the MGM controllers, their building them to custom specs as we speak. I got a email two days ago showing the custom cap packs that they’ve completed. Controller specs are
2-14s
100 amps continuous
140amps for 10 seconds
180amps for 3 seconds
Has cost me 1800 euro so I hope it works😬
nice to hear that you start the deal with MGM
I really really really hope that your massive investment will turns out good for you.
I told you about my expierences with MGM in RC applications some years ago, so i hope the best.
Have you pictures from the ESC itself?
This Capbank is for both ESC or you got 2 Capbanks?
Massive 7500uF you got with one!
Compared to YGE 9-Caps each 390 = 3500uF
Specs dont sound that much better as from the Roxxy i think.
12S-120A
Of course 14S is better but most motors have a 10 some 12S limit, which motors you choosen?
Hey Jenso👍🏻there is two capacitor banks of 5, the caps are pretty big 16 diameter, 35 high.
I could of gone for a larger esc but the physical size would of Been to large to fit on the back of the board with a bigger cap packs + the reciever and Bec.
The motors are enertion 6374 that I’m making longer shafts for so I can run a bearing support.
Batterys are 4 6s Turnigy graphene 6000mah, connected in series and parallel.
I don’t have photos of the esc’s that there making yet but they will look something like the following pic.
The controllers have pretty advance configurations and adjustability with real time data logging comparable with vesc.
Hope they work, I’ve been told to run them at 6s to start off with then check the data feedback and send the results to MGM and they will give me a starting point for 12s.
After sending a link to your fireworks vid they are saying that your problem would be
caused by constantly overloading the controllers when you get off and on the throttle causing peek burst current to often in a short period of time…
who knows really but I’m going to ride mine like it’s stolen, 2 years warranty so so I’ll put that to the test.
