I thought they were comming out in clear colors… and ticker urethane (??)
So far at half time:
Evolve/ABEC 1 vs Trampa 0
I’ll put a single one on the scales for you. The urethane we used is very special and can be very soft. Rebound is as high as it gets with urethane. This is not the standard stuff usual manufacturers use for their wheels.
I’ll push the product forward as much as possible.
Frank
Violet, Orange, Yellow, Neon Green, Neon Blue… pleaseeee!!
Some other pic for you guys And between 9 - 8 and 7" I make a custom rim for them - it will almost look like this :
I think they will have Orange + Black. Give them time, the product just came out! You kidz so impatient these days.
Orange (from their instagram)
Black (this seems photoshoppy because it looks like e-board porn but I have seen black ones, somewhere, I think @Nowind got some black protos a while back):
Black gummies on black hubs looks sick, like you would ride on hubs only , love it and can’t wait!
Then I guess that makes sense too – maybe he doesn’t have much time
not EXACTLY what i was getting at but…
holy crap that gave me a good laugh
Precisely
308gr per Gummy. For comparison: Regular Trampa 8" Tire with inner Tube: 309gr. 153gr for a Hypa Hub 187 for a Superstar.
Set on Hypa Hubs: 1844gr Set on Superstar: 1980gr
At 125 mm diameter that is 3.96gr per mm of wheel diameter for a single wheel (on Superstars). That is 21% lighter than regular urethane wheels weigh per mm diameter. If you use Hypas you are 30% lighter in comparison.
Colours: Surprise Surprise… Black will be part of the range.
The ride is nice and smooth, since we use a special formula for this tire + the cross section is a lot thicker than the appearance suggest. The tire fills the entire bed of the hub.
Frank
Well spotted. This is a prototype. Final production model comes with a very tiny valve. 100PSI should be no issue btw.
Frank
I am confused why the gummies have an inflation valve? Thought they were thane thru and thru
I am not 100% sure but I think it could have been irony.
Having (4) in front of me and so beautiful they are
But they seem to be thane thru and thru…
Maybe I am missing something or someone’s been eating too many gummies
How in the eff can I buy a board with these on it? You gotta buy the parts and DIY it?
