Do you know where I can purchase a charger and a good BMS for a 12s4p 20700 setup?
Check with Kaly.NYC or BKB. For the BMS and get at least a 6a charger but preferably an 8a.
Ok, thanks!
Does the kaly direct drive fit on the mini spring hangars with 6374s?
Iāve got an Urban Carver too which I want to upgrade to a dual direct drive but donāt know what the best option is. I donāt want to be forced to get longer hangars.
Thatās probably a question for Kaly - shoot him a message on instagram. He sends them already mounted on a custom hangar. So if it was a $ issue then you would probably only be looking at purchasing 1 instead of 2.
Thanks. Iāll contact him then.
What type of screws do you use to mount that under battery?
Hey, how did you fix the battery enclosure on carbon deck?
Thanks a lot
