Progress finally on a voltage booster.
I was sketched out about using my 2S many P vruzend kit due to the 4A per cell limitation, and because of the overall size. Also, it really is a mishmash of cells from all over the place, but at least the P groups are as closely matched in overall Ah as possible.
Regardless, I decided I don’t need to go 48 mph weighted, up from 40mph on my current gearing with that crazy pack… whatever it is.
So I used some old salvaged LG laptop cells to put together a gigantic 1S pack to boost voltage 3-4v, giving me an extra 3-4 mph top speed.
It’s a 1S26P. The cells capacity tested out to around 2750mah each, so 71.5Ah, or 257Wh. This is nice, because hopefully I won’t have to charge it as much… Maybe once every 4 times I take it out. I needed a P group much larger than my main batteries 4P because of my main packs range extender / boost converter that I carry an extra 400 - 600Wh to charge while riding… And that won’t be keeping this voltage boosting pack charged, only the main pack.
The cells are only rated for 5A discharge, so I needed 26 of them to reach my boards max battery load of 80A. Each cell should only need to output ~3A to match the 80A requirement, also I don’t want to push old laptop cells to their 5A limit.
I used fish paper where the 12AWG wires run on each side and before wrapping it all up tight I sealed everything up with electrical tape and around the protruding wires with I padded with some 7mm thick or so thick neoprene rubber and a final layer of craft foam to make sure that no matter what I’m taking any stress/pressure off the nickel strips, since I wasn’t able to fish paper underneath (they were already spot welded on from being in the laptop batteries, and I figured I’d just keep and reuse them as-is so I wouldn’t be soldering on top of the cells directly). I’m pretty sure this will suffice, having the standard terminal ring and battery wrap, since the pack itself was also hot glued like crazy in every single open crevice and taped over again and again.
I don’t have any other pictures of the build, but each side has two 12AWG silicone wires splitting the load to the main +/- which is 10AWG. The whole thing plugs into my loopkey and tested out it adds 4mph to my top end successfully. Tomorrow I’ll be doing some stress tests on it.
