… … !!! older … hahahha thanks a lot Andy for your time and the feedback !! I will make the correction ^^
In fact actually, the pcb isn’t fixed at all … I was thinking tight fit, but you right, I will need more precise modeling for this, I will try to take time this WE for that for sure with the 3 screws to old it properly. Hold it, sorry
But it is temporary, I will maybe make a new dual heatsink and go!
At the end it will be like the MadBox : it fits all the wiring, receiver, bt module. And it will be for esk8 (dual case, under or upper and emtb same !).
Nice build. Btw your 6 shooters are on backwards. The tread pattern is designed to scoop water from the center of the wheel and push it out the sides as it rolls. the way you have it, it will scoop up water from the sides and bring it towards the center of the tire and that’s an accident waiting to happen. Just swap your wheels from left to right.
I know. One of the rear wheels is like that too. I have not turned the tire around yet because I’d have to remove the pulley that’s screwed in with locktite. I’ll fix them when I change wheels again. I have my street wheels on right now.
