https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7324?u=riako want the same setup !! beautifull mate !
Hi guys, I posted a photo of my Trampa with concave and I’d like to create a topic to show you how I did it but it looks like I’m not able to create a topic. Do you know why? Thx!
Evo deck, 10s4p 30q, racerstar 5065 200kv, evolve trucks and mounts, boardbumpers bearing adapter, trampa urban treads, 15T motor gear 66T wheel gear. Rides like a tank. IMO don’t use the evolve trucks I have them wedged as if you don’t the front truck will be slanted and lean down. They’re super wobbly at speed and really high up with this setup. I have TB 218 trucks on order and plan to switch to dual 6374 190kv maytechs.
beautiful work.
Click here: https://www.electric-skateboard.builders/c/e-board-builds
Then please select [+New Topic] (if memory serves)
@treenutter is an admin, perhaps can help.
Looks great ! ervinelin make almost the same on his Lacroix, but in a different way. Here I like, that you enlarge the trampa deck ! Yes got big foot. Wan’t the same bro !!!
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7311
i need dis, can you link it?
I think it’s it :
Got this one dual, working super great seens last year,… I saw it un quad too …
Thanks thanks thanks a lot bro !!! Once my printer is back from don’t know where the fµk it made it !
oh i see, it’s a balance charger. thought it was a volt monitor.
nevermind, carry on.
Riako’s got it right The more expensive one does faster balance charging… mine caps out at 2.2 amp per channel when balance charging which is a little annoying
Nice design! Would you mind to share the stl files with us?
Thanks mate! Yes of curse I will share it but it needs some or should I say a lot of perfectionments … I was talking about that here : The main problem is that actually, my printer is not working so I’m a bit embarrassed to share without a test … I put it on Thingiverse
This was fast and easy, but I don’t know anything about Licence so I let the standard one set…
Looks good so far. Made something the same for my focboxes and wanted to design it for my Flipsky too. Just didn’t had a time yet. So very cool that you made one To seal the heatsink with silicone works fine for my focboxes, so that‘s should work with yours too. Did I understood it right, the pcb is fixed only with one of the three screws to the holder? If you designed it for mtb‘s to be mounted on top than don’t forget there is a receiver and a Bluetooth module which need a space too. Would be nice if that could be stored inside too.
Just as constructive feedback Ah and you forgot a H in the thingiverse titel.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7335?u=grozniy If only this was a lie
What monster will it be?
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7341?u=riako please want one pair of this toooooooooooooo please please please !!!
