thanx!
actually it is the closet under the stairs of the first floor.
but it is it’s really nice working most of the time because it’s connected to the living room
thanx!
Can you edit this and have enough space for a davega?!?
I would buy it in a second : D
There is already this design for a DaveGA…
Gear drive bearing
link?
Thanks ;D
Char
haha nice one
What’s going on here?
What’s this going on?
For use on a LaCroix deck, hybrid street/my setup.
Are these stock axles? I would be worried the extra length added will increased force onto the threaded part of the hanger causing it to eventually fail
No stock are 50mm - 80mm. Most of us use 90mm tho.
Yeah I thought 80was the max stock they offered. That extra 30mm of length will be adding 38% more force onto the hanger, idk what SR tolerances are but that is a significant amount more force
I really want a 200mm tkp hanger. Maybe even 210mm.
They are not stock, but they are hardened to 12.9 and have tensile strength of 1600 lbs. I think they will be fine.
Yeah whats the deal with that pat said, I dont know much about it look at gear drives for example their hangers are like 100mm wide and the axles are like 300mm?
Yes but with SR the axle theads into the aluminium hanger, it doesn’t pass all the way through like other trucks.
@mmaner I’m not worried about the axle bolt but the hanger where the bolt attaches as that is where all the force is taken. (Well assuming you are talking about the axle bolt)
