It’s this thing, I found it linked from Reddit’s 3d printing sub
It doesn’t beep, but it could with a buzzer shield & little work forking the code on github
It’s not necessary for the cell to be curved. I think I’ll just make it a bit bigger.
Its def using potentiometers and not encoders, which means that it’s limited in how far it can rotate.
I have built a remote using rotary encoder and it is pretty useful. Great for constant speed, but does require re-wiring you brain a bit (and a deadman-switch).
I just liked the form-factor of that remote you posted.
did you use dye on the normal green urethane wheels? or did i miss a special edition orange refly??
It’s got some gears on the side meaning that they probably drive the potentiometer. The reduction ratio can’t be seen fully but this could either help for it to rotate a further distance or shorten the distance
Those look like regular green Flywheels dyed black
I dig em. They should make those
Slightly smaller cast
Niiice, its recovery well? right?
Yes? It seems so but he said its hard to tell without another MRI. Just gonna keeo pushing it and sees what happens lol.
Yep I used dye, painted on repeatedly with a cotton tip. Cold. When the wheels are new and the skin is shiny you have to repeat over and over
Damn your pale af
Well, he is sort of a Vampire. Sleeps during the day and works at night holding a 24cm chef’s knife in his hand.
Pretty much
I always interview the guys before hiring them to perform in the same movie with you Pat. Would never want you to be left unsatisfied
I appreciate he consideration xx
Nice board and workspace
