Not sure which size replacement jack I’d have to get
Probably 5.5mm x 2.1mm
Slowly, from China or quickly, from USA
Don’t forget to buy original formula JB Weld
Thanks. I can measure it up with my calipers to be sure
The pin in the middle will be either 2.1mm or 2.5mm. All esk8 stuff I’ve seen uses 2.1mm
WARNING: don’t stick metal in the charge port until you snip the wires!!
snip the wires one at a time please
Also don’t snip them while the charger is plugged in
Not all sparks are from shorts. I have a boost converter charger and when plugging that in it makes a big spark. However, if I power the charger on first and set it to the right voltage then plug it in there is no sparks at all, I think it is due to the capacitors on the charger. This sometimes happens with the small 10s charger I have too
Saved my life. I was pretty close til I looked at the messages lol. But I can’t tell whether the inside is 2.1 or 2.5mm. It’s really close to both and of course I didn’t touch it with the metal calipers
I have never seen esk8 parts with 2.5mm pins. So you have about the same chance of being correct by buying the 5.5x2.1, as you would have of finding a scratchers ticket that isn’t a jackpot winner
TL;DR: buy 2.1
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/9203?u=riako epic pic !!!
New wallpaper! Thanks to your friends Justin
https://amadridefr.files.wordpress.com/2019/01/pic_0130w.jpg
Damit, @mmaner even at work I see your silowet in everything…
Wait a minute… If I start seeing you in the TP during a BM I’m going to have to stop PMing you so much…Blaaaaha
ROFL. I’m famous
What enclosure is that?
La Croix enclosure
where are these PCBs from?
esk8life, but I think he’s out at the moment. I’m putting together a batch for some MTB builds
Can I have my 12s5/6p made with these modules? They look great
Nevermind I’ll wait
Also I’d like to talk configuration and pack size, as I don’t want it to be top mount anymore
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/9215?u=riako Hoooo yeeaaah party started !!
