https://www.lipolbattery.com/high%20rate%20discharge%20lithium%20polymer%20battery.html
In order to install the battery in a limited space, it became such a layout. The size of the battery itself has become quite limited.
・Dual FOCBOX ・3D Servisas FOCBOX heatsink ・3D Servisas Anti spark switch with PTS ・Own board carbon deck ・3D print enclosure ・4500mAh 20C Li-po ・Flipsky hub motor ・evolve 83mm front wheel ・exway deck tape
These were used. A clone beyond the real Exway.
Been called out on this a few times haha I promise it wasn’t planned
What are you using as a stand?
Made it from some scrap wood. And 4 bicycle type hanging hooks.
I gotta do something similar soon.
I’ve wanted to see this since the Stary board, congrats.
would be very thankful to see performance and telemetry on your build, brother.
very, very cool build. even easier than the Foosted for new builders.
great job!
here’s the link to the deck @LEE used, in case anyone else is interested. I did not know Ownboard sold this deck, great find.
Because I used FOCBOX, building became difficult. 10S Battery, 10S Hub Motor, WOWGO ESC, It becomes easier if assembled with these. Li-po can be constructed by soldering, so you can challenge even if you do not own a spot welding machine. You can probably install a battery pack that exceeds 200 Wh.
I guess it would be unprofessional if he said dear Mr. Sweet Cheeks
hmmmm maybe I could join the “Me Too” movement if he did that
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/8588?u=grozniy Prototype for trampa mounts?
Yes it’s 2 piece I’ve been using it on my other motors it’s super solid they don’t move.
Finally. Iv’e been waiting for TB to make this change. I knew those single piece versions only held by grub screws would only last so long…
Yeah it’s so nice plus it has idlers I love the free roll.
My 4wd free rolls better than some hub set ups.
