https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7335?u=grozniy If only this was a lie
What monster will it be?
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7341?u=riako please want one pair of this toooooooooooooo please please please !!!
… … !!! older … hahahha thanks a lot Andy for your time and the feedback !! I will make the correction ^^
In fact actually, the pcb isn’t fixed at all … I was thinking tight fit, but you right, I will need more precise modeling for this, I will try to take time this WE for that for sure with the 3 screws to old it properly. Hold it, sorry
But it is temporary, I will maybe make a new dual heatsink and go! At the end it will be like the MadBox : it fits all the wiring, receiver, bt module. And it will be for esk8 (dual case, under or upper and emtb same !).
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7353?u=skunk What’s the top? Looks good
Nice build. Btw your 6 shooters are on backwards. The tread pattern is designed to scoop water from the center of the wheel and push it out the sides as it rolls. the way you have it, it will scoop up water from the sides and bring it towards the center of the tire and that’s an accident waiting to happen. Just swap your wheels from left to right.
Good catch. I’ve seen that on cars and left notes on their windshield
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7356?u=mynamesmatt how heavy are these?
I dunno it’s things like this that trigger my OCD haha
I know. One of the rear wheels is like that too. I have not turned the tire around yet because I’d have to remove the pulley that’s screwed in with locktite. I’ll fix them when I change wheels again. I have my street wheels on right now.
Just a 10S 2P 12Ah auxiliary battery for range extension (approx. 30km more)
do you have this hooked up to a step up converter?
yeah -this one set to 42V 6A
As it is they are pretty heavy, but they will machined to fit a bearing, I can see in the CAD tomorrow the final weight
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7362?u=grozniy Nice looking. What tire will it accommodate? What pulley is compatible? Price?
@brenternet https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7364?u=mmaner
Besides being a good ay to get shot in practically any major US city, whats going on here ? Is this real or what?
Gummies to 8 inch Any pulley designed for superstar will work Price around $50 per Hub, will include axles to replace the stock on ultimate trucks.
Aluminum 7075-T6 Bearing 6200-2RS 10 mm Axle included, Hardened Stainless Steel
Straight from the man himself.
Nice! Exactly the price I wrote on Instagram i thought it’s going to be But how to change the axle? I thought they pressed in the hanger?
