Nice design! Would you mind to share the stl files with us?
Thanks mate! Yes of curse I will share it but it needs some or should I say a lot of perfectionments … I was talking about that here : The main problem is that actually, my printer is not working so I’m a bit embarrassed to share without a test … I put it on Thingiverse
This was fast and easy, but I don’t know anything about Licence so I let the standard one set…
Looks good so far. Made something the same for my focboxes and wanted to design it for my Flipsky too. Just didn’t had a time yet. So very cool that you made one To seal the heatsink with silicone works fine for my focboxes, so that‘s should work with yours too. Did I understood it right, the pcb is fixed only with one of the three screws to the holder? If you designed it for mtb‘s to be mounted on top than don’t forget there is a receiver and a Bluetooth module which need a space too. Would be nice if that could be stored inside too.
Just as constructive feedback Ah and you forgot a H in the thingiverse titel.
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7335?u=grozniy If only this was a lie
What monster will it be?
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7341?u=riako please want one pair of this toooooooooooooo please please please !!!
… … !!! older … hahahha thanks a lot Andy for your time and the feedback !! I will make the correction ^^
In fact actually, the pcb isn’t fixed at all … I was thinking tight fit, but you right, I will need more precise modeling for this, I will try to take time this WE for that for sure with the 3 screws to old it properly. Hold it, sorry
But it is temporary, I will maybe make a new dual heatsink and go! At the end it will be like the MadBox : it fits all the wiring, receiver, bt module. And it will be for esk8 (dual case, under or upper and emtb same !).
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7353?u=skunk What’s the top? Looks good
Nice build. Btw your 6 shooters are on backwards. The tread pattern is designed to scoop water from the center of the wheel and push it out the sides as it rolls. the way you have it, it will scoop up water from the sides and bring it towards the center of the tire and that’s an accident waiting to happen. Just swap your wheels from left to right.
Good catch. I’ve seen that on cars and left notes on their windshield
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7356?u=mynamesmatt how heavy are these?
I dunno it’s things like this that trigger my OCD haha
I know. One of the rear wheels is like that too. I have not turned the tire around yet because I’d have to remove the pulley that’s screwed in with locktite. I’ll fix them when I change wheels again. I have my street wheels on right now.
Just a 10S 2P 12Ah auxiliary battery for range extension (approx. 30km more)
do you have this hooked up to a step up converter?
yeah -this one set to 42V 6A
As it is they are pretty heavy, but they will machined to fit a bearing, I can see in the CAD tomorrow the final weight
https://www.electric-skateboard.builders/t/no-words-just-pictures-delete-words-use-pm/2992/7362?u=grozniy Nice looking. What tire will it accommodate? What pulley is compatible? Price?
