You can’t imagine how perfect this represents us : (
It’s quite ridiculous but I have to say that we are just not ready. Although the website is done and actually turned out way better than I was hoping, I don’t want it to just say out of stock or pre-order for the board and drives.
We’ll swap the countdown for an email subscription as it’s quite obvious now that we aren’t capable of correctly estimating the time required. Exactly the reason why I didn’t want to start a thread about this.
On the good note, the drives are turning out to be incredible little beasts, and I truly think you’ll all love them! Just not tomorrow)
If you keep this honest and humble approach is gonna be fine. The fact that you want to make all things right only means you care about it. Good luck man I wish you the best
No, not anymore. Silver turned out to be much softer than copper and after winding multiple stators, the wire would either crack or break entirely on some of the bends. 1 out of every 5 motors had a broken wire which got really expensive so we ditched the idea.
Yes and no. You could push an equal amount of current into silver and copper, silver just wouldn’t get as hot.
We were able to achieve a very efficient overall motor design, and we can fit just a little less copper than a 63mm motor. So if you stay under 30 continuous amps, efficiency shouldn’t be problem.
For the drives? Yes, we’ll be offering the dual kit for $449 and the 4WD for $699 with shipping included.
The drivetrain’s will be complete with your choice of wheels.
@BoostedBuilder What’s the max speed on those? how silent are they? stability on high speeds?
let’s say it different: possible to come by and test them?
Ahmyo Akasha wheels will come as standard, larger wheels will have a higher price (for example, kegels +$10). The wheel choice will be from what we have in stock and we don’t have TB wheels. If there is interest for Europeans, I’ll place an order.
Max speed literally? I’d say somewhere around 50mph at 13s, in 4WD and with 110mm wheels but never tested. Pleasantly silent in FOC. I’m not sure how motors affect stability so I don’t know how to answer your question.
Sure, when we’re done, you can come by and test them)
