Great, I will contact you after the test is completed this week.
Did you decide how you are going to make the Box, Not the bevel gear
I don’t have any new ideas yet.
i mean, if the box is not complex, you could maybe outsource it and save cost.
Thanks for your advice I will evaluate it again.
well looks like i know what i am gonna get for christmas
the braking didn’t sound healthy though - were the teeth skipping?
I imagine there is some flex with the wheel/motor/mount etc that would make skipping pretty inevitable, i feel like youd frequently lose optimal contact between the pulleys when going over bumps or when breaking/accelerating
The brake looks like no problem. Maybe I pressed the video too early. I think I need to open it to check.
Brake tests are only meaningful under load - without the mass of a rider that needs to be slowed down the observation will not reflect what’s going on in real life. What I meant to ask was if you could FEEL some teeth skipping (like one can with a belt driven system).
I understand what you mean. There is no problem with teeth skipping now, but I think I need to do more testing.
The developments are looking really good. Keep it up.
That deck in the video, its like 1 foot long. it could be a chopping board.
That’s really like a chopping board Not easy to control because it is too small
when you max your agility stats on the cost of everything else^^
Update! Received it over the weekend from @MorrisHsu, gonna put it through its paces today!
That looks so cool
That’s sick, keep it up! And once you finish updating it, maybe think of ways to reduce the sound of gears.
That looks terrible.
Shit. This is going to be the new standard isn’t it.
Lube. Closed case.
