I have just finished today to build my board and made my first run few hours ago.
But I have speed issue, it doesn’t go very fast, maybe 10 or 12 miles/hour, and torque is not that big too. I was expecting much much more…
Here is my setup :
10S Lipo 5000mAh (2 x Turnigy 5000mAh 5s 25C in series)
Motor mount is from ebay, so I had to make new holes to adapt it to my motor, the belt tension is quite hard now. Can it be the cause of my speed issue?
The wheel is a bit hard to turn by hand.
Oh yeaaaa !
You’re right, I totally messed up battery setup of VESC
Now it’s like a missile, 60A for motor max is even too high, I almost kill myself 2 or 3 times, it’s so powerfull now !!
I will tweak settings a little bit, I have now trouble with my motor mount, pulley of motor is almost gone because screw went out with vibration …
Anyway, electronic is working fine and this is great !
Thank you for your help
i have a dual motor set 6374 190 kv motors with a 12s4p battery it works fine but when i press the throttle all the way up one of the wheels stops spinning i have screen shots of my BLCD TOOL here. so i want to fix the issue !
