In Dingle the bars come looking for you, went to Ashes, had some very delicious Oysters and steak to follow
Thanks OKP, that’s means a lot
There’s so many bars there. I work there every once in a while, marvellous place. Dick Macks bar. A bar and cobblers, quite remarkable.
Dick Mack’s is good craic there is so much choice, next time you’re in Dingle sure give me a shout
Ben let me know when you’re going so that I can jump in with you. I’m going to put my bicep up against Alan’s head, flex it, and knock him out cold.
That’s cock, lock and two tiny barrels, do you want a daag with that?
Some ankle protection and a pair of tights
Hummie thane really looks great
When u do finally get it going I highly recommend the foc program w 30khz switching. Probably said it
Lately foc and that higher frequency’s efficiency has been questioned on this site and people are testing (maybe u) but it’s still the smoothest and most silent.
Thanks will do that for sure
The yellow shrink showing through was too annoying so fixed it
What size cable sleeve is that?
Wow you don’t mess around. You definitely covered that maybe 1cm of shrink showing.
10mm iirc 10 chars
Stealth to draw the eye away
Please take good pics and explain before you seal it all up in there. I’m doing the same. Looking into using a solid compressor instead of the Poron foam though w imbedded contacts. Silicone solid for such a thing needs be custom molded and can’t pour the good stuff at home so using Poron too likely
The balance wires are a concern, grounding any of them out against the aluminum deck would be a disaster. My solution was to sugru them into position
Then just on top of the cells a 1.5mm silicone layer, kind of like this
I surrendered to the Kama
Still not happy with the clearance although I did not test with the special thin NESE cell packs on the NESE thread, I don’t really want to backstep into printing trays again and refitting the hardware so considering taking up yoga
Going to open it up more like a gasket
