Yep, I checked out some openbuilds, most of which were pretty sweet. I’d love to be able to make my own size and everything, but I just don’t see myself pulling it off…
I think I could build the frame and get everything mechanically set up, but I’d start to fall off the deep end when it comes to software and connecting all the electronics: I really just don’t see myself buying all the right parts, and being able to get it all together and working properly.
The Xcarve does require you to put it together, but it comes with everything you need and it a relatively simple package. I’ve seen a couple people in the RC world get them, and they were by no means experts in building CNC machines.
All that said, I am still a couple months out from placing any sort of order, so alot could change!
also, do you have any openbuilds that you particularly like, or have really good detailed explanations of everything? Thanks!
finally got my VESCs up and running in tendem over the CAN bus after some initial issues with one of the VESCs. Had to reflash and then upgrade to 2.07 FOC, but now i’ve got traction control and everything. My 14yo son made the bus cable for me and we both learned a lot about crimpers and pins and what not to do. lol
I’ll post more pics tonight. I actually have the VESCs in there now with it along with the reciever, so dropping the box is a matter of 8 bolts and 6 plugs. Modularity for the win.
regarding the flex in my decks, last night as an experiment i added some fiberglass to the bottom of one of my decks to see if that would stiffen it up some more. We’ll see where that gets us when the resin is cured. if it works, i can continue with this build as is and one-off it. If not i basically trashed a deck for science.
I have also spoken with a guy i met on instagram who is not too far from me about carbon fiber layer options on the bottom of my decks as well as carbon fiber boxes, so that might happen as well depending on what he can do for me. That’s kind of blue-sky at this point though.
Lastly, i’m in the process of getting a quote from my veneer supplier about 9 and 11 layer kits. This will probably be the route that i go, but every option is worth exploring. 9 or 11 layers and vac formed boxes is the most likely candidate for what i do moving forward. It’s probably the easiest and most flexible set up and would allow me to do more rapid prototyping.
All of this is to say that i’m taking a multi-pronged approach to stiffening the deck (or working around the flex) so that heavier riders don’t destroy their box. I like the monolithic box design because it’s the most flexible as far as what components go into it. A split box design would allow the deck to flex but would require some serious hacking to get a space cell to work with it, but that’s probably my second option if the quote for 9 layers doesn’t pan out how i want.
looks like the quotes for 9 and 11 ply are not as ridiculous as i imagined. As soon as i hear back about how much the freight will be (they forgot to include that in the estimate) i’ll probably just order the 11 ply kit today and start ordering those moving forward so that i’ll have the flexibility to press any thickness i want.
That being said, i’ll likely be offering 7, 9, and 11 ply variations of Scarlet at different price points and box configurations. Something for everybody! thinner flexy decks in twin box configs, and 9 and 11 layer decks for monolithic box configs. Hopefully my mold can handle the extra thickness without doing something retarded.
yes i still have the box thing to work out. I have everything i need to build a vac forming set up, so i’ll probably be doing that while i wait for the veneer to show up.
He’ll yeah! bounce testing has revealed a significant drop in deck flex with the added patch of fiber glass. Now I just have to sand it down cleanly and paint it.
I tested by standing on both my black metal push board and the recently fiber glassed scarlet I’m using for this build. Jumping up and down on both has revealed that the red one is no longer flexing any significant amount (for me anyway) so I’m going to finish up this build. Maybe I’ll test a split box config on the black one next.
Thanks! Black metal scarlet did turn out to be a pretty fierce looking beast. Was on it in my bare feet and that coke bottle grip felt great.
given the flex if you want to go with one long box i would do a wooden box and maybe glue it to the deck and clamp it, then use some sort of lid. The one you did on that arbor was absolutely gorgeous. otherwise, you can get away with an ultralight ultrathin fiberglass box if you also fill that w-cave channel on the bottom with about 10-15 layers of fabric and resin. I already forgot how many layers i used in this one.
i just did a stand and jump block test with the box bolted on and it didn’t crack after repeated jumping, so i think we’re good. I’m out in the garage right now re-staining the wood i sanded and am planning on painting the fiberglass after taping it off. its getting coke bottle grip as well.
I think I will do a split enclosure 6s build… similar to my pocket rocket, but with wood enclosures and styling more like my arbor. Plus I will incorporate a better charging port, xt90 anti spark loop key, volt meter, etc.
But first, I’m going to buy an X-carve I’m so close to being able to afford one, and right now I’m in the process of building a board to sell to someone who has wanted me to make them one for a long time… hopefully after making their board, I will buy the X-carve, and then whip up some sweet wood enclosures matched perfectly to your deck’s w-concave!
I imagine the build to be a good cruising board for when I don’t want the power of the space cell, and when I want to let others ride my board. The one problem with the space cell is that if you aren’t expecting it, the trigger sensitivity is a bit much- especially for someone who is riding an eboard for the first time and have no clue about how fast it can actually go…
ok so i finally got the vescs configged and enough of he flex out of the deck to put this beast together. She’s 19.8 pounds of spit and venom and once i got the box on it was time for the trigger test. So i grabbed up my Chief Trials & Engineering Inspector so he wouldn’t get run over and we did this thing.
Don’t worry about the smashing sound. It was nothing. Honest!
i want external USB ports on this build, so i’m going to track something down and share it if i find anything. Settings tweaks should be able to be done in the field in my opinion.
I don’t know the clearance you have, but a panel mount usb would make a clean solution. In my book, square holes are a pita, i like sticking to round holes.
I have a question @longhairedboy.
If you are ruining dual vesc’s, but not using canbus and instead just splitting receiver signal. Can you program your vesc’s one at a time? My concern is that they will both be powered up while I update one.
I think one at a time is the only way to program them. its ok to have them both on and only one plugged into the PC.
Unless i’m mistaken, you just give them identical setups and tell them to both use PPM. Since they are each independently receiving an analogically split signal they must each act as if they are the only vesc at play.
Which is kind of a shame really because you’re using more wiring to do less amazingness. using the CAN bus allows them each to understand what the other is doing at any given point. Not to mention traction control which can only be a good thing, even if most people don’t use it.
i’m telling you this despite the fact that i sell analog signal splitters on my site. lol
I just want both to do the same thing. Personally I don’t believe anyone will ever prove traction control does anything on a longboard. And a little “loose” is a good thing on a longboard.
