Hey guys,
So far my build is at £668 which is just too much, especially considering I don’t even have the deck yet. I’d really appreciate if someone could look through and help me cut down the price to £500 or below without losing a lot of quality and/or compatibility of parts.
Thanks, Cal
p.s Sorry for so many links
£120 http://www.trampaboards.com/infinity-trucks--solid-hanger-body-with-12mm-solid-axles--mega-strong-p-11151.html x2 (with bolt kit)
£10 http://www.trampaboards.com/12mm-x-28mm-red-abec-5-bearings--fits-to-12mm-axles-p-12141.html x4
£3 http://www.hobbyking.com/hobbyking/store/_62933__HXT_4mm_Bullet_to_XT90_Battery_Adapter_2pcs.html?strSearch=4mm%20bullet%20to%20xt60
£100 http://www.hobbyking.com/hobbyking/store/_37501__Turnigy_nano_tech_5000mah_5S_25_50C_Lipo_Pack_UK_Warehouse.html?strSearch=nano-tech%205000%2025 x2
£2 http://www.hobbyking.com/hobbyking/store/_31809__XT60_Harness_for_2_Packs_in_Series_1pc_UK_Warehouse.html?strSearch=Xt60%20ser
£125 http://www.vesc.co.uk/product/vesc-4-12v-bldc-controller/?attribute_setup=Premium
£70 http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=38037
£0.50 http://www.trampaboards.com/magnetic-keyway-connects-the-motor-pulley-on-the-motor-axle-p-13730.html
£1 http://www.ebay.co.uk/itm/HIGH-TENSILE-CONE-POINT-GRUB-SCREWS-ALLEN-KEY-HEADLESS-SOCKET-M3-M4-M5-M6-M8-M10-/162145801317?var=&hash=item25c0a49465:m:mTC11QhNGqW9ulATH8dIgFw x2 (M8 x 16) £20 http://www.trampaboards.com/high-torque-drive-htd-5m-5mm-tooth-height-high-power-hp-460mm-long-x-15mm-wide-strongbelt-for-trampa-mountainboards-54-p-12913.html £15 http://www.trampaboards.com/14-tooth-x-15mm-wide-motor-pulley-htd--connects-into-the-trampa-electric-skateboard-motors-37-p-12856.html £40 http://www.trampaboards.com/66-tooth-slave-wheel--fits-15mm-belts-to-superstar-hypa--primo-wheels-1-66-tooth-slave-wheel-for-mountainboard-1-p-12860.html?remove_key=34315&qty=2&offer=0 £3 http://www.trampaboards.com/m4-x-40mm-regular-hex-head-bolt--marine-grade-stainless-steel-with-locking-paste-69-p-13091.html x6 £25 http://www.trampaboards.com/urban-carver-mini-spring-truck-motormount-truck-connector-t6-cncd-for-street-carver-45-p-13627.html £30 http://www.trampaboards.com/urban-carveboard-motor-mount-panel-for-mini-spring-trucks-left-side-5mm-thick-3k-twill-matt-carbon-fibre-p-13628.html £1 http://www.ebay.co.uk/itm/M4-M5-M6-M8-M10-A2-STAINLESS-STEEL-COUNTERSUNK-BOLT-CSK-ALLEN-SOCKET-SCREW-/181276846436 (M5x16) x4
£80 http://www.trampaboards.com/7-inch-wheel--matt-black-hypa-hub-with-black-inline-7-inch-tyre-hh-w70--7-inch-wheel-p-12793.html?remove_key=34316&qty=4&offer=0&attrib_234=1396&attrib_63=814 x4 (with 12mm spacer)
