I have some LiPos I want to hold down in one of the WowGo metal enclosures, but hot glue isn’t sticking, velcro is too thick, and epoxy is too permanent. Anyone have a good alternative, removable solution?
If you can’t use velcro then whatever you use will not be easily removable. A good 3m double sided tape will work or if you can wait for it to cure then a neutral cure silicon. Easier to remove the tape than the silicon but you can get it off again using a thin bladed knife. Do it in small blobs and the removal won’t be too problematic. Are you talking remove to charge or remove when they need replacing?
Mate I can go to bunnings and buy a 3m tape that is black and about 1.5mm thick. Sticks like shit to a blanket. Go on the 3m site and try to find it. Not as vibration proof but it does give some protection. @pat.speed your fine mate just go to bunnings. I use it on my rc cars for the electronics and it holds well.
