Hey @whitepony , I will be routing a loaded vanguard 42" flex 2 for my build as well, 2 channels between the battery and ESC enclosures. I’m looking at 10 gauge silicon wire and they are 5.5mm in diameter. That seems like it would be a really deep channel and might make the deck too weak. Do you have any advice?
What kind of resin did you use to attach the veneer? I have 3m Bondo All Purpose Resin for fiberglass, does it need to be some kind of flexible resin? Really worried about putting some epoxy on the board that will make it either too stiff or crack.
