Visually Looks like the copper fill on this motor is slightly better than the silver ones? I do like that they made the bearings smaller because these large ones were so close to the ground they attract dirt and water like crazy
I think so. Itās quite messy tho and loose at the top. That could be because if you look closely a screw has hit the end of the windings damaging the windings.
Imo the bearings are great. I like them big since it will split the force over a larger area and last longer. Iāve replaced mine with ZZ seals so they seal better than the stock with low friction seal.
Good pictures
Usually people find a rubber seal, like 2rs, is more protecting than the double sided shield ZZ.
Some of the bigger bearings are weaker (seemingly carvon). If itās not at least 7mm wide I bet itās weaker than a skate 608.
Maybe the motor suffer from the vibrations of those many loose thin wires eventually rubbing off their insulation and shorting.
Oh Sorry i ment 2rs. Zz is steel i think
So @onloop where are we on this DIY community cooling hangars? Can we develop better stuff than you or are we locked at using stock hangers?
Iām sorry if I misunderstandā¦ Was there anything wrong with them?
No they were good
If anything is used as DIY, there is always some limitations to the usage! But who cares about it (if you just ignore the support )
@onloop answer the question please, I dont want to waste Carlās time.
There has to be something to do with people who ignore legal inquiries
I believe it shouldnāt be a problem since they are not using this ātechnologyā anymore, now is liquid chilly. Iām in!!
I suppose your company does since patent application? BTW remember guys that it is not valid in EU
So at least EU builders (DIY or commercial) you can build and experiment safely with this type of technology without legal worries.
IMHO you should just focus on bringing better and better products and creations, thatās what this community lives for.
Maybe make a 3d printed cover that goes over the trucks?
They wonāt be able to proof anything!
All jokes aside. A clear answer is still missing. Can we make and share mods without legal problems?
Isnāt having community mods a great thing for a brand? Show some support to this crazy mods Enertion!
It would be sad if a company comming from DIY to kill it ^^ Guess itās tricky to give a straight up answer
Once upon a time.
