coooool, good to hear they’re around and working!
Im thinking of building one with some large car batteries to use as portable fast chargers. couple AT boards at a big park, BBQ and riding all day woop woop
I am in between a small pack I can clip to the middle of my board such as this 7S2P that will be enough to get me where I need to go… or if I should just go all in and have the option for this 10S5P with enclosure that I could also strap onto the top of my deck, stuff this thing inside, and basically double my range instead of adding less than a quarter of my current range (1.25x instead of 2x the current watthours) with the 7S… and be able to not only get where I need to go but have waayyyy enough wiggle room to cruise the extra long routes back and forth.
I was originally looking at purchasing a BMS, wire, connectors, cases, a boost converter, individual cells, and DIYing the whole thing, but it looks like I can get a lot more cells with a built in BMS going the pre-made route. This way, all I have to do is connect the pack to a boost converter, program the boost converter, mount it, and plug it in when I want the extra range.
The advantage I saw of putting my own together from scratch was the performance from quality cells. But, the fact that this will just be drawing a relatively small continuous current, and not directly affecting the boards performance… only supplementing it, I don’t really care about having super high quality cells… only capacity.
I would really really love to supplement my current 10S4P with a 10S5P battery to charge while riding. I wonder how close this would be to basically having a 10S8P or 10S9P battery- hopefully somewhat comparable for range, but im going to assume surely not alike for pure amp draw potential of a 10S9P.
I am sold now. Picked up the boost converter, a range of high voltage fuses with various amp ratings and fuse holders…
Hesitant to order batteries from China, I checked out Lowe’s. I didn’t expect to find much in terms of price competitiveness, but the portable power tool batteries are actually priced equal to or better than the Chinese batteries per watt hour!
Two of these batteries comes out to 192 watt hours. Add in the quick charger and the price comes out to be cheaper than a “LG/Samsung” 6S4P 211 watt hour battery without charger from China. Not only is it cheaper, I can design it to be 100% modular with 3D printed mounts / boost converter enclosure that all just snaps onto the board… plug and play additional batteries as needed, carry extras in the backpack to hotswap on the road. Sounds so nice! Plus no shipping cost to save $35, and get them today
I see a fun project on the horizon.
I don’t know if it’s something I did wrong, or if the converter I got was faulty… But it died on me after an hour of charging- screen flickering, power output ceased, unit got very hot, fan turned on and turned off… Now it’s dead. My excitement is dampened. This is the one I got. It was great, charged really fast at 5A when it was working… Got my board from 30 to 60% in relatively little time compared to my standard 2A brick charger.
I’m swapping it for a new one now… Hopefully this one doesn’t just die on me… With the slightly reduced range on my pneumatics, I really could use the extra range now. I’m still trying to think of a clever way to mount the unit and battery holder to my board, rather than just clipping it to the top… But I’ll probably just keep it clipped to the top. Maybe I’ll go for a rear mount to keep it out of the way. Having clip on extra range will be great, I’ll keep dreaming for now until one of these boost converters actually works.
I can vouch for this charger, I use it to charge my 12s build at about 3-5 amps with an input of 24v.
This is making me want to buy a 6s lipo
Unfortunately I already ordered another one. If these things in general are as finicky as the first one I got and the second different kind kicks the can, I will definitely be going off your word and picking that one up. Thanks for the recommendation!
As for the one that is coming in the mail tomorrow, I drew up a rear mounted battery / boost converter holder that integrates with my steering damper in the rear. I tried just plopping the various designs together, but I ended up starting from scratch. Pics posted in the pics no words thread, but i’ll post them again here since this is more the topic for it.
I designed the boost converter enclosure to be modular, to slide on and off as needed… and I will probably use some 3.5mm bullet connectors to hook it all up so I can keep the battery clip installed and wired up… and if I need to try the boost converter you suggested then I can draw up a new enclosure with the same attachment, print, wire it up, solder bullet connectors to the new converter, pop it on the pack of the board and just plug it in without having to re-print eeevveeerrrryyythinnnggg.
Okay, burnt out my second boost converter. I think third time will be the key. Made an anti spark switch, no more Sparks… Gonna draw up and print an enclosure for this new boost converter. This thing looks well soldered, and is quite hefty. Thanks for the suggestion @pat.speed. also picked up a watt meter per pats suggestion.
Edit 1:
Wired up to test and working mmmmmm!!! Voltages and amp outputs of the meter are accurate enough
Edit 2: After some testing, first 4AH battery charged my 10AH battery by about 30%. If second battery charges to 70% before empty… The math in my head says this boost process is about 70% efficient… And I am totally good with that … it will get me back uphill and home from work with greater than 1% battery to spare,which is all I need. I am a happy camper at the moment, none of the wires are overheating and everything seems to work well now.
If anyone in the US is curious, these are the two things I ordered for this from Amazon:. Boost converter… and this fairly accurate enough watt meter.
Now to draw up the final enclosure and dye everything black.
Got it all hooked up and working! Now I just gotta cable manage a bit…
Okay, here’s a photo vlog:
I’ll probably update when I get the cable management down.
nice one! How did you mount the boost converter with the heat sink poking out?
I have mine on the bench testing at the moment, same parts but with a lipo. so far its good
The heatsink mounts to the boost converter on the four corners of the PCB, with four 6mm tall spacers between the heatsink and PCB. I thought this would be a great place to mount everything, in place of those spacers to print a Nylon shell for the PCB, with a cutout in the bottom of the shell for the PCB to make contact with the heatsink, and just let the heatsink hang loose out the bottom (I’ve since secured it to the deck as an additional point of strength for mounting the entire assembly.
Anyways… Here are some pics of the cable management. I ended up running the charge cable under the lips of my enclosure… And the charge port when not in use just wedges securely under the battery enclosure lip… Totally didn’t plan on doing it this way (I had no plans, just winging it).
And a little video of hooking it up as if I were on the road… Such a satisfying click.
Got to try this out today. Two batteries, each drained half way… After 4.5 miles only dropped from ~39v to ~38v with 4P 25r charging at around 3.5-4A… the board meter reading somewhere around 80-85%, down to 75% when I got home. This was all while riding my higher power mode pushing 80A battery max with sligly reduced 16A battery min to compensate for the additional continuous charging.
I also notice a volt or two less voltage drop in the higher power modes, and it just feels noticably snappier for the voltage I was riding at.
I thought I would attach the batteries when I needed the extra range, I think I’ll probably just ride with the batteries all the time now.
I need to make a few changes: E6000 to protect the electronics from bumps and vibration, hot glue to better secure the ingoing and outgoing wires to the boost module and for better water sealing around the edges of the boost module enclosure. Also, I need to solder on an extension to the negative output wire from the boost module- it’s just a tad too short for comfort at the moment.
Sorry for bothering you. I just joined this group. How can i post? It does not seem to have any link for post new topic…
Huh, for me there is a new topic button on the main forum page.
Maybe for new users there is a limitation until you have so many posts or something.
Yeah you need to have a certain amount of time on the forum I’m pretty sure, let’s delete these posts after a day as to not clutter this awesome thread
Cool! Does this just plugin directly to your charging port?
Yes it does…
So 6s is the minimum battery config to use for this, is there any advantage in using a higher config say, 10s?
And how efficient is it when used while riding? If you have 10% battery left and you plug it in, will it be able to charge it fast enough for the battery not to get empty while you continue to ride?
The problem with 10S is that you would need a DC-DC converter that can step-up and step-down, they exist, but are harder to find
To make simple and only use a step-up the minimum skate battery voltage should be higher than the maximum battery booster voltage with some margin between the two
10S fully discharged = 28~30V 6S fully charged = 25.2V 7S fully charged = 29.4
wouldn’t plugging into the loop key blow something up? the loop key completes the circuit on one rail whether it be positive or negative. if you added another battery it’d essentially need another antispark. wouldn’t it?
it will definitely blow up
we’re using boost converters to charge through the charge port while riding.
